Final thoughts before purchase in the 3500lb+ cab range?
   / Final thoughts before purchase in the 3500lb+ cab range? #11
Very happy with my Boomer 40 cab. Small front tires bothered me compared to Mahindra I was comparing it to. Cab is very quiet, ac is cold on a hot day and heater keeps windows clear at -20 with ac compressor engaged, which can't be done on many tractors. Loader visibility is great but had to rimguard rear tires to drive with loaded bucket. My only real complaint is 3pt lift isn't very high for loading/unloading from trailer. Hydraulics are very smooth. Rear wiper, cruise, mid-pto, and 2 remotes being standard were a big deal for me compared to other color tractors. I also have confidence my dealer will be there when I need them and have qualified techs and tools. Other Korean tractor dealers seemed sketchy in service at best. Kept my JD 1070 20 years and parts/service meant a lot to me.
   / Final thoughts before purchase in the 3500lb+ cab range? #12
No doubt a ...... "mini excavator is easily 10 times faster".
How fast is it when you need to just dig two or three relatively small holes, and the mini is sitting in a rental yard, X miles away?
Problem is, in 26 years living on my place, I’ve rented an excavator 5 times. No use owing one.
now as an electrician I could have used a backhoe a lot, but I found it easier to hire an operator to dig while I followed behind placing pipe and wire. I didn’t have to haul equipment, I got job done faster and the homeowner paid for the ditch so who cares. Also no backhoe to maintain and insure.
ill bet you dollars for doughnuts 95% of the people with backhoes on their tractors just use them for counterweight. I mean really, how many holes do you dig unless you work at a cemetery.
So are the small front tires (T Rex) actually a problem or they just sort of look disproportionate? While clearance is better on a larger machine, I do like the feel of the lower center of gravity on the smaller size.
And I don't think I will use $8k worth of a backhoe. I would probably spend more time taking it on and off than using it. I am sure there will be times when I REALLY wish I had it, but I can work around that.
   / Final thoughts before purchase in the 3500lb+ cab range? #14
Around here, I can rent a good sized mini ex for $500 a day delivered and picked up... and that includes 2 buckets and a hammer attachment. Not that I really ever need one much anymore. I was thinking one time about purchasing one years ago for my business, until I started working with a contractor that Own’s 2 of them for his business. Always working on them keeping them running. Mind you he uses the heck out of them, but they are high maintenance machines.
   / Final thoughts before purchase in the 3500lb+ cab range? #15
Clearance doesn't mean nearly as much to me as a smoother ride from larger tires.
   / Final thoughts before purchase in the 3500lb+ cab range? #16
For me, it is not a question of backhoe economics, I always want to have a BH at my disposal,..... to make my life easier!
Those times needing an 11' BH (with thumb) come up more often that you might think,.....especially when you are 80 years old.
It is NOT all about digging!
At about 20 hours per year, my Kubota L48TLB maintenance is minimal, and replacement value insurance is included on my homeowners policy!
Example: Last year I dug out my old 1,000 gal. fibreglass underground fuel tank, and crushed it with the hoe and thumb. Then placed the debris in the bottom of my dump trailer.
Only other way, would have been to rent a mini for at least a day, and the mini would need to be delivered and returned, from 30+ miles away.
Would have been very pricey!
   / Final thoughts before purchase in the 3500lb+ cab range? #17
The loader bucket does look like it’s out there a long ways. That can be good and bad. Bad because it does hurt how much you can lift. Good because if your dumping near the edge of a hole, it gets you back further, same thing if your clearing brush, further away is better.
Hard to compare because you are looking at a much bigger tractor than I own, but I owned a Kubota BX for several years and traded for a JD2025r. The JD is bigger and has a larger loader. When I went to dump something off the edge of a gully I noticed the JD seemed like I had to get closer. I looked up the specs and the loader bucket is closer on the JD than the Kubota, even if it is bigger. You may appreciate it being out farther.
   / Final thoughts before purchase in the 3500lb+ cab range? #18
Fried, you aren't supposed to tell me you use the BH a lot! Now comes the second guessing!!!
Love the look of the Yanmar but the closest dealer was many hours away, a $50k price tag and a couple month delivery.
Wow. Way overpriced for what you are getting.
   / Final thoughts before purchase in the 3500lb+ cab range? #19
One thing to keep in mid is... A rear mount blower is a power hog, especially in heavy, deep snow. I run an 80" Lucknow 2 stage on my M9000 Kubota (92 horse pto on the dyno) and my Lucknow uses every bit of it and then some of the snow is deep and not fluffy. I can make it smoke if I get in a rush and it's turbocharged too.
Way back when I had a 5030 HSTC (my screen name) and I had a Woods 36" 2 stage on that and even the Woods used every bit of horsepower the 5030 made (I think it was around 45 pto) and there were times it need more.
You need to consider that when buying anything. Blowers are power hogs.
The blower will be the biggest power eater of anything you want....
If the snow of light and fluffy, no issue. When it gets heavy there is always a power issue. and in Maine, at least northern Maine, there will be a lot of snow. Southern Maine, not so much.
Just my opinion from years of experience.
   / Final thoughts before purchase in the 3500lb+ cab range? #20
I am sure that a backhoe is not for everybody, but I doubt very seriously that most who have BH's would now be willing to surrender them.
To put it into perspective, there are two more bits of BH information I should share.
#1) I am 80 years old, and do not try to pick things up that weigh more than 70 lbs., or wrestle around much more than 200lbs.
My yellow lab pup weighs 71 lbs. That is really all I can lift.
#2) My L48TLB hoe has an 11' dig depth, so it is a light construction type piece of equipment, and is able to lift, push, pull, or dig, substantially more than a 6' or 7' hoe.
I do also have the L48 loader with bucket, quality EA quality forks, and a medium duty generic grapple.
Sometimes though, only the BH will do the desired job (private).
My Kubota L48TLB will remain in my barn until I am firmly planted under ground,..... perhaps, it could even be used to dig that final hole for me.
NEW Fork Extensions (A59000)
NEW Fork...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Online Buyers Premium (A55272)
Online Buyers...
LOT: (2) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (2) Kimball...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
