DUMB place to put a grease nipple.....
   / DUMB place to put a grease nipple..... #1
JonKioti
Newfoundland, Canada
CK-20S HST
..is under the stabilizers, pointing downward, with NO protection around it. It's one of the lowest items under the end of the tractor on the KB 2475 backhoe on the CK20.
I did a complete grease job on Sunday, and found both of these had broken off. One was gone completely, the other looked intact until it popped off inside the grease gun nozzle.
I presume these need a metric thread, as the hex part appeared to only fit a 10mm wrench. Can anyone tell me for certain?
What a stupid place to put a grease nipple without any kind of collar around it. I'd weld one on, but I'm not keen on welding upside down, nor taking the thing apart to turn it over. Anyone dealt with this before?
Jon
   / DUMB place to put a grease nipple..... #2
Jon
Is it on the end of a cylinder? If so take the stabilizer off and rotate the cylinder 180 degree and put back on.
   / DUMB place to put a grease nipple..... #3
I have a 2485 backhoe and found the grease nipples breaking off in the grease gun. The factory nipples were found to be thin brass, very flimsy. As they break off I replace them with steel nipples, five so far. Mine are standard SAE, 1/8, I think.
   / DUMB place to put a grease nipple..... #4
I don't have the backhoe for my CT122/ CK20, but the grease zerks on the tie rods that I have had to replace were metric.
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
2022 Kubota RTV-XG850 Utility Cart (A56857)
2022 Kubota...
Troy-Bilt Push Mower (A55973)
Troy-Bilt Push...
2018 Peterbilt 567 Garbage Truck (A55973)
2018 Peterbilt 567...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
2023 Kubota...
