Duetz fuel pump???
/ Duetz fuel pump??? #1
Kays Supply
Southern Illinois
Iseki TA 207
I have a friend with a Duetz engine on a wood chipper. The fuel pump has failed. Is there any reason he can't bypass it and put in an electric?
/ Duetz fuel pump??? #2
I would think that if you knew the output pressure of the pump and the capacity of the pump, you could replace it with a comparable electric. However, since Duetz is still an available source for parts, is there a reason to try to rig it, rather than to just replace it?
I thought about doing the same thing with an auto in the driveway, but finding the right replacement is a problem. Most sources don't want to quote you the specs on a pump, just sell you a new one.
David from jax
Several factors. This is on a wood chipper. It is almost impossible to get at to replace. It is a 1984 model. There has been an ice storm and his phone is ringing off the hook. You get the picture. If there is a pressure bypass, what would extra pressure do to the injector pump?
/ Duetz fuel pump??? #4
go ahead and bypass it whe have had custoners do that all the time the injector pump does not care if there is a little more pressure than normal it will run just fine
2012 Honda Crosstour Hatchback (A66738)
2012 Honda...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
TRIN  BOTTLE TRAILER (A67714)
TRIN BOTTLE...
AGrotk 680 QA Drop Hammer (A64912)
AGrotk 680 QA Drop...
2020 John Deere 6120M (A64911)
2020 John Deere...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
