Duals
/ Duals #1
rmillerces
Mi
Massey 135-Massey1250-JD650-JD770-International industrial loader
Hi All...
Anyone ever mount duals to compact tractors? Just got a Massey 1250 with R1's. Lots of sand and some fairly steep hills to mow (brush hog) on my property. Seems like duals would help both stability(roll over) and traction in deep sand.Thanks for the input.
/ Duals #2
You can try it but it will void any warranty as duals put too much stress on the rear axel. You will probally destroy the bearings and seals and maybe even the tranny if you use it any amount.
<font color=blue>Robert Turk Jr.</font color=blue>
<font color=blue>Whitetail Splendor Deer Farms</font color=blue>
<font color=blue>Silver Creek, NY</font color=blue>
/ Duals
Thanks for the reply Robert. I guess I'm thinking that if anything got torn up it would be the axle itself. Lets say I'm in sand with just the original tires.They spin. Axles spin in the bearings. So I mount the duals and head back to the sand. Tractor hooks up and wheelies! Where is max load at that point? Remember that the bearings are free to spin at will so I'm thinking that the axle shaft itself is trying to rotate on it's centerline. If the axle is stronger than the gear that drives it then the gear breaks-sooner or later (we are in soil and not on pavement). So what we are looking for is the weakest link. Anyone want to guess?
/ Duals #4
As much as I hate to get off the original topic it is about duals though. I am wondering if a truck come with single tire rear and I wanted to put a dual kit on the truck will there be damage done to the vehicle? What I'm contemplating is using deep dish rims and new extended studs? Any comments would be great. Thanks
Darin
/ Duals #5
Darin,
Yes they make kits to convert your single to dually.
/ Duals #6
The duals stick out farther so if you go over bumps you will raise the inside tire off the ground if the outside catches, this has more leverage and the leverage puts the pressure to the bearings it also can cause the axel shaft to bend depending on how much weight the tractor is hooked to. You can try it and I have seen tractors with duals, mostly older Ford tractors but I would talk to my dealer before I try it and see if they can recommend anything to help.
/ Duals #7
If you are going to duals just for traction please ignore this post.
If you are doing this for load capacity -- be careful. Ask your tire dealer for the load rating when mounted in a dual configuration. It won't be 2 time the single mount load capacity, but the total will be a lot more than a single mount tire. The derating is due to the increase in temperature between the tires and the requirement that the sidewalls never touch each other.
Matthew
/ Duals #10
Picture of Duals
/ Duals #11
Miklos,
I looked at these conversion kits for 3/4 ton trucks, and it appears that these are just for looks?
Or does this really upgrade the GVWR of a 3/4 (~8800 lbs) to that of a 1 ton (~11,000 lbs?) ?
The reason I ask is I got the impression that the ford F350 has a heavier rear axel than the F250. Also I suspect that the springs are different?
Fred
/ Duals #12
Miklos,
Thanks for the web address and am checking it out now. Sorry for the delay but been away from TBN for a bit and dont' think I will be able to catch up. /w3tcompact/icons/frown.gif but will try.
Darin
F-150 4WD (A63689)
F-150 4WD (A63689)
Bush Hog 3Pt Post Hole Digger (A66408)
Bush Hog 3Pt Post...
2023 New Holland Powerstar 90 Tractor (A65579)
2023 New Holland...
2022 ALLIANCE NORTH AMERICA AIR MAN SDG 25 GENERATOR (A65643)
2022 ALLIANCE...
2012 PETERBILT 386 (INOPERABLE) (A65643)
2012 PETERBILT 386...
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
