Dual purpose mount plates (SSQA & 3ph)
   / Dual purpose mount plates (SSQA & 3ph) #11
Certainly not picking on the OP's original intent at all.
If I have the capability to build a puller, adding the SSQA part would be very easy. So why buy a plate that I then have to adapt to my puller design? :)
No offense taken at all, it’s a valid question.
It’s partly so I won’t have to fiddle with the figment and the ability to notch the bottom holes & bend the top catch plates. Figured I could “fast forward” things a bit.
   / Dual purpose mount plates (SSQA & 3ph) #14
It痴 partly so I won稚 have to fiddle with the fitment and the ability to notch the bottom holes & bend the top catch plates. Figured I could 吐ast forward things a bit.
No bending needed if you start with a square tubing frame. This is how they built my stump bucket:
And the dimensions:
   / Dual purpose mount plates (SSQA & 3ph) #15
Thanks X. That's way better than me tryin to explain it. :)
   / Dual purpose mount plates (SSQA & 3ph) #16
I have one from Titan that allows me to use SSQA on the back.
I had to do some modifications (cutting and welding) to make it work with my Quick hitch though. Kinda pissed me off as they coulda made it that way with absolutely no extra cost or time.
   / Dual purpose mount plates (SSQA & 3ph) #17
Could you clarify this? (It fits your SSQA FEL but it is not QA-compatible) thanks.
Sure. My Land Pride forks are SSQA-compatible. I then modified it later to fit my 3PH. However, at the time, I did not have my QA, so didn't take the QA into account when I modified my forks. I mostly just made sure that the 3ph stuff didn't interfere with the SSQA interface.
I should clarify: I don't *think* it fits; but I haven't tried it yet. I got my QA on sale, then it turned cold around here last November and I haven't had to or needed to change from the 8' grader I have on the back right now.
   / Dual purpose mount plates (SSQA & 3ph) #18
Walmart in the states carries everything. Thats awesome. You would never see anything like that in walmart in Canada
Walmart doesn't carry it, they are just being a "marketplace" for the transaction. If you dig into it further it says "Sold and shipped by Titan Attachments."
They are doing this to compete with online sales from Amazon.
If anything, their actual stores have a lot less variety of brands now (very often just one or 2) compared to 10 years ago.
The saving grace is that they will often do free shipping to a store for pickup, and will accept returns at the store rather than having to pay for return shipping.
   / Dual purpose mount plates (SSQA & 3ph) #20
The angle of the top piece and the angle of the bottom piece are not the same. And neither are 90 degree in relationship to the wall of the plate, or of the square tubing if that's what you use for your frame.
I built the basic frame. Then clamped it to the FEL SSQA. Then i used that to add the brackets to the puller. Very easy.
One more tip. When you add the jaws of the puller have the frame you just built fastened to your FEL. Have it adjusted so your bucket level indicator is in the level position and on the floor. Then add the jaws level. This lets you continue to use the level indicator as you do with the bucket on. :)
iDrive TDS-2010H...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2018 HINO SA (A58214)
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2018 KOMATSU PC138USLC-11 EXCAVATOR (A60429)
2018 KOMATSU...
