DSL install info needed
   / DSL install info needed #11
Correct. Bottleneck for just that PC. As far as 11Mps.... I'm spoiled. I have an 802.11g wireless/wired router in my house. My wifes laptop (which is wireless) connects at 54Mps. I'm very spoiled..........
Regards,
Dubers
   / DSL install info needed #12
The basic DSL modem only provides one IP address to the inside of your house. If you buy a simple router for $29.00, it will take that IP address for itself. Then you can set the router up to provide IP addresses to all of the computers in your house using DHCP. You can then hook up as many PCs to the router as it has jacks for... usuall 4. Or, you can hook up a switch, hub or any combination of them cascaded to give you 250 jacks to hook up as many devices as the router can supply addresses for, usually 250 or so devices. If the router you buy also has wirelless capbility, all the better, as you won't have to hard wire anything.
You should have no problem hooking up a wireless access point inside of the router using either a jack on the back of the router or through a switch.
I was a Staples last year and picked up a wirless router with support for 250 devices, 4 hard wired ports and a PCMCIA wireless card for a laptop $29.00, so deals can be had.
My current home network consists of a DSL modem, a wireless router with 4 jacks on the back, and three PCs hard wired to it. The wireless router provides IP addresses to my three PCs and any wireless laptops/devices that come into my home. It works very well.
   / DSL install info needed #13
You can get a print server to sit on your network. You can usually connect up to three printers directly to it, instead of a PC. That way, no PC has to provide print sharing. Any PC on your network can print to the printers on the print server. They work very well, too.;)
   / DSL install info needed #14
Our experience with the wireless router is good, it still has some quirks. The biggest problem is the radio signal will not penetrate the log walls ( log home) in our home. We have had to do a little figuring and basically have a line of site between the transmitter and receiver. A wired router would have been better but with no place to run hidden wires, it was not an option. If you have a regular stick built house this will not be an issue. The firewall is great and be sure you encrypt your signal per the instructions provided for security.
   / DSL install info needed #15
No doubt! Definately you want to enable WEP Encryption. Don't want drivers by piggybacking on your wireless connection.
Regards,
Duber
   / DSL install info needed #16
Instead of multiple replies....
1. I have a Belkin Pre-N wireless environment (AP and PCMCIA card), so it's faster than 54 mbps. :)
2. I use WEP encryption AND MAC address for security.
3. I buy printers with built in networking, so no need for a print server.
More update.
I just got of fthe phone with embarq.. It is a small fee to upgrade the 'regular' modem they send to one that is a modem/router/wireless B /G access point.. so.. that is the way i will go.. Also comes with a usb/G adapter for a 2nd pc in another room...
Sound good?
Soundguy
   / DSL install info needed #19
Soundguy said:
More update.
Sound good?
Soundguy
Real good as they probably "support" what they sell :)
~paul
That was my hope as well.. get it all from them.. that wy i got 1 person to call to get it ALL working..
Soundguy
Adams 16T Tender Body (A56436)
Adams 16T Tender...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56436)
Bulk Lot of NEW...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
Kubota B2301 (A53317)
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
