Loader DS3510 3rd funtion Kit
   / DS3510 3rd funtion Kit #11
I would try but all the fittings at the valve itself are straight thread and have O-Rings for sealing on them.could put the 90 itself on the valve fittings, but, did not want to mess with those fittings if I could help it. I am an Aircraft Maint. Tech. and mess with O-Rings and they can get nicked, cut, damaged just looking at them it seems. Then they leak. So, I don't want to pull them to get fittings on..
Thanks for asking tho.
Tom
Tom, No problem- I hear you on the o-rings and such- better left alone what already works.
What's your thinking on how you're going to protect the lines/valve?
   / DS3510 3rd funtion Kit #12
I had my diverter valve installed on the loader, although i have nothing to use it for:(.
I'll PM you my postal address to help you out:D
   / DS3510 3rd funtion Kit #13
   / DS3510 3rd funtion Kit #14
If you guys don't mind me asking, how much are you paying for the electric diverter valves and what all comes with them?
   / DS3510 3rd funtion Kit #15
Mine did cost 550$ installed with all hoses and fittings, ready to use. Thats up here in Quebec so don't know how much you guys are paying.
   / DS3510 3rd funtion Kit #16
To the OP: Are those elbows you put on the top steel and designed for high-pressure use? To my eye they look suspiciously like galvanized pipe elbows. If steel, please disregard.
Yep, Steel fittings. I would not use anything else on my tractors. I have used aluminum fittings for 3000 psi on aircraft, but, my tractors are not aircraft.
As for the guard, I was thinking 1/8 steel bent into a "U". 1-1/2 leg, then a leg to cover the valve, with the 3rd leg about 1-1/2 bent at a 45 going aft.
the first leg will have the 2 bolts thru.
Everything above the sentence "I think this explaination" was the explaination. Where I found it is listed below. Reason I found it, was it had been referenced in another thread.
TractorByNet.com > New Holland/Ford > New Holland Owning/Operating
"TC30 3rd function kit for FEL"
This link was started 11-22-2005
Hope this helps
Tom
   / DS3510 3rd funtion Kit #18
Yeah, I saw what I thought was the same thing, and I was wondering if they are suitable for the application...
I take it they're not if galvanized?
Wow, Guess Tom and I posted answers/questions at essentially the same time....
   / DS3510 3rd funtion Kit #19
Hope this helps
Tom
Tom, I know that you said that the 90s were steel and not aluminum, but are they high pressure steel? I have never seen a hydraulic 90 like what you have there. It looks like it is for water or gas. :confused:
Tom, I know that you said that the 90s were steel and not aluminum, but are they high press ure steel? I have never seen a hydraulic 90 like what you have there. It looks like it is for water or gas. :confused:
I know. They are temporary. I had to order all the proper steel ones I needed. Only found two in the 4 TSC stores I went to. I should be changing them out by next saturday If I am lucky and they come in.
If I wanted to do tubing, I have the flareing tool for the JIC fitting. There is no big problem using the 37 degree JIC with the 37-1/2 degree aviation flare. Much better than using the automotive 45 degree flares that some use. I no longer have a source for the aviation steel fittings. Unless, I ordered from Aircraft Spruce or similar company.
Still, It is cheaper to buy from TSC or such as those fittings do not have an FAA PMA. (Federal Avia. Admin. - Parts Manufacturing Approval. Which in my opinion, jumps the price up greatly)
72in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
72in Dual Cylinder...
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
Deere 410L (A53317)
Deere 410L (A53317)
Tafe 45DI (A53317)
Tafe 45DI (A53317)
