Loader DS3510 3rd funtion Kit
   / DS3510 3rd funtion Kit #11
I would try but all the fittings at the valve itself are straight thread and have O-Rings for sealing on them.could put the 90 itself on the valve fittings, but, did not want to mess with those fittings if I could help it. I am an Aircraft Maint. Tech. and mess with O-Rings and they can get nicked, cut, damaged just looking at them it seems. Then they leak. So, I don't want to pull them to get fittings on..
Thanks for asking tho.
Tom
Tom, No problem- I hear you on the o-rings and such- better left alone what already works.
What's your thinking on how you're going to protect the lines/valve?
   / DS3510 3rd funtion Kit #12
I had my diverter valve installed on the loader, although i have nothing to use it for:(.
I'll PM you my postal address to help you out:D
   / DS3510 3rd funtion Kit #13
   / DS3510 3rd funtion Kit #14
If you guys don't mind me asking, how much are you paying for the electric diverter valves and what all comes with them?
   / DS3510 3rd funtion Kit #15
Mine did cost 550$ installed with all hoses and fittings, ready to use. Thats up here in Quebec so don't know how much you guys are paying.
   / DS3510 3rd funtion Kit #16
To the OP: Are those elbows you put on the top steel and designed for high-pressure use? To my eye they look suspiciously like galvanized pipe elbows. If steel, please disregard.
Yep, Steel fittings. I would not use anything else on my tractors. I have used aluminum fittings for 3000 psi on aircraft, but, my tractors are not aircraft.
As for the guard, I was thinking 1/8 steel bent into a "U". 1-1/2 leg, then a leg to cover the valve, with the 3rd leg about 1-1/2 bent at a 45 going aft.
the first leg will have the 2 bolts thru.
Everything above the sentence "I think this explaination" was the explaination. Where I found it is listed below. Reason I found it, was it had been referenced in another thread.
TractorByNet.com > New Holland/Ford > New Holland Owning/Operating
"TC30 3rd function kit for FEL"
This link was started 11-22-2005
Hope this helps
Tom
   / DS3510 3rd funtion Kit #18
Yeah, I saw what I thought was the same thing, and I was wondering if they are suitable for the application...
I take it they're not if galvanized?
Wow, Guess Tom and I posted answers/questions at essentially the same time....
   / DS3510 3rd funtion Kit #19
Hope this helps
Tom
Tom, I know that you said that the 90s were steel and not aluminum, but are they high pressure steel? I have never seen a hydraulic 90 like what you have there. It looks like it is for water or gas. :confused:
Tom, I know that you said that the 90s were steel and not aluminum, but are they high press ure steel? I have never seen a hydraulic 90 like what you have there. It looks like it is for water or gas. :confused:
I know. They are temporary. I had to order all the proper steel ones I needed. Only found two in the 4 TSC stores I went to. I should be changing them out by next saturday If I am lucky and they come in.
If I wanted to do tubing, I have the flareing tool for the JIC fitting. There is no big problem using the 37 degree JIC with the 37-1/2 degree aviation flare. Much better than using the automotive 45 degree flares that some use. I no longer have a source for the aviation steel fittings. Unless, I ordered from Aircraft Spruce or similar company.
Still, It is cheaper to buy from TSC or such as those fittings do not have an FAA PMA. (Federal Avia. Admin. - Parts Manufacturing Approval. Which in my opinion, jumps the price up greatly)
Harley Davidson (A56859)
Harley Davidson...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2015 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-65...
