Dryer fire hazzard
/ Dryer fire hazzard #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
My clothes dryer quit producing heat on last Thursday. Took the lower panel off and WOW, there was a TON of lint in there that had accumulated over the years.
Took shop vac to the lint, replaced the thermocouple & thermostat and all is well HOWEVER, I never realized just how much lint can accumulate INSIDE the dryer.
Do yourself a favor & take the 30 minutes needed to pop the cover off and (if needed) take your shop vac to your innards.
I told my wife to try to remind me about doing that every six months or so. I don't know how high that is on the "risk of fire" scale but it sure was visually bad enough for me to think I was lucky.
/forums/images/graemlins/tongue.gif
/ Dryer fire hazzard #2
Good reminder.
Another good idea with dryers is to replace the plastic vent hose they used to sell with the metal hose that is required in most places now. A flash fire in the metal style hose will likely not leave the hose. The plastic melts quickly and "fooont."
Cliff
/ Dryer fire hazzard #3
Rich,
It also amazes me how much crap accumulates in and around the dryer. I dismantle and clean the entire vent pipe and also the dryer itself at least once a year, sometimes sooner. I can't ever remember going to a residential fire where the dryer was the cause but it could happen easily!
Thanks for the reminder.
/ Dryer fire hazzard #4
You guys are on the right track. Clean that dryer out at least once a year and preferrably twice. I've been a firefighter for 23 years and have witnessed at least a dozen "Dryer Fires" only one caused extensive damage.That was because the folks left the house with the dryer running. Just a hint, but refrigerators collect lint on the coils and can overheat as well.
/ Dryer fire hazzard #5
We just got a new washer and dryer (I had replaced the belt on the old dryer this past year and the inside was full of lint) and I noticed that they specifically recommended to NOT use the aluminum foil flex hose, FWIW.
/ Dryer fire hazzard #6
</font><font color="blue" class="small">( We just got a new washer and dryer (I had replaced the belt on the old dryer this past year and the inside was full of lint) and I noticed that they specifically recommended to NOT use the aluminum foil flex hose, FWIW. )</font>
Odd, the code requires it here, that is in situations where pipe is not an option, of course.
The plastic kind has ribs which catches the lint, then it melts easily if there is a fire. The metal hose is not ribbed, but is flexible none-the-less. I can't imagine why they would say the plastic was better.
Cliff
/ Dryer fire hazzard #7
Cliff,
I realized after I hit the post button that my post was probably not entirely clear - but I was too tired to remedy it last night. /forums/images/graemlins/blush.gif
They don't recommend the plastic either - as I recall it was strictly pipe or one of those periscope type units.
/ Dryer fire hazzard #8
</font><font color="blue" class="small">( as I recall it was strictly pipe or one of those periscope type units. )</font>
Ah, then we're talking about the same stuff. It's expandable metal duct that I would call semi-rigid. It expands out or can be bent around a corner, but once expanded, you can't really put it back very easily.
Cliff
/ Dryer fire hazzard #9
As a Fire Marshal, I second the hint on not leaving any dryer run while you are not home. Most fires started in a dryer can be caught early and extinguished if an adult is home at the time.
Shooter
/ Dryer fire hazzard #10
I have also heard that its not a great idea to start the dryer and go off to sleep.
If I was to pick the rooms I would most want to have fire spinklers installed in my house, the laundry room would be in the top three. The other two being the garage and the workshop.
I wonder if there are any good stats on what rooms house fires usually start in. I would imagine that ashtrays, candles, and fireplaces have to be a big part of the distribution as well.
- Rick
/ Dryer fire hazzard #11
It is also a good idea (and often code required) to use fire resistant caulk where the pipe goes through the wall. Be prepared though, the last tube I bought was in 96' costs 17 bucks.
My dryer pipe run is fairly long. I added a Fantech dryer fan to it to properly exhaust the lint. The fan has a barometric sensor on it so it automatically starts with the dryer and runs for ten minutes after the dryer has stopped.
/ Dryer fire hazzard #12
Is that the red fire caulk? Ive used this red fire caulk in buildings on pipe systems. Its great stuff, but its really messy. Once it dries on your clothes it dont come out .
/ Dryer fire hazzard #13
</font><font color="blue" class="small">( If I was to pick the rooms I would most want to have fire spinklers installed in my house, the laundry room would be in the top three. The other two being the garage and the workshop.)</font>
Your first pick should be the kitchen. Most fires (minus smoking and electrical) originate in the kitchen.
/ Dryer fire hazzard #14
</font><font color="blue" class="small">( Is that the red fire caulk? Ive used this red fire caulk in buildings on pipe systems. Its great stuff, but its really messy. Once it dries on your clothes it dont come out .
)</font>Thats it!
/ Dryer fire hazzard #15
RE: Your first pick should be the kitchen. Most fires (minus smoking and electrical) originate in the kitchen.
Yes, but usually when my wife starts a fire in the kitchen, she is right there to put it out and serve it up.
- Rick
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2016 Ram 5500 Flat Bed (A63688)
2016 Ram 5500 Flat...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
2016 P.J. Trailer Trailer, VIN # 4P5F8202XG1252798 (A65563)
2016 P.J. Trailer...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
