Driving tractor with the front end loader bucket elevated .
   / Driving tractor with the front end loader bucket elevated . #71
Seems like I'm always moving something heavy. Big rock or pine tree trunk. Back when I had the Ford 1700 I was moving a single large rock in the bucket. Front tire dropped into a hole or depression. It happened so quick - no time to think or react. Fortunately - I was using my "knuckle dragging" technique. Carry the load so low - it leaves drag marks in the dirt as I move forward.
The tractor dropped and pitched to the right. The low bucket caught the tractor and gave me time to make corrections. I was crossing my east meadow - it's almost flat as a pool table. It's the unseen that will do you dirt.
   / Driving tractor with the front end loader bucket elevated . #72
I try to stay low. I have to lift it to get through gates when the fork is loaded, however. When I carry a lot of debris, the FEL is usually a couple of feet off the ground to prevent things hanging off of it from catching on weeds and things.
My most fun experience with the FEL came while using a rope to pull shrubs. The rope was not centered, and when the FEL went up, the tractor started rolling onto the side with the rope. The speed of the roll was impressive.
Impressive!
   / Driving tractor with the front end loader bucket elevated . #73
We mow a pretty steep hill - 15 acres.. First time mowing, we did not have a FEL. Like someone else, we were hoggin 10' material - could not see what was on the ground nor how the ground was shaped.
Went super slow..
Found lots of scarey stuff in the field. The previous owner had a passion for rock piles. He made them about 18" above the ground. You might say they were fun surprises to find!
The next year we put a FEL on the tractor and ran the field with the bucket low and curled for stability on the hills and as a braille method to find those damn rock piles.
By the third year, had a great idea of the lay of the field and wanted better vision. Dropped the bucket from the SSQA but wanted some weight out front on the arms so we run the fork frame without forks. Gives just the right stability and still allows the braille method when needed. As I am training others to run the field so I don't do all the mowing, I always suggest the fork frame be 12" off the ground. Doing so keeps them from trouble on the rock piles on a steep hill.
Arms up high? Not on these hills. Arms are put up around fences and speed is reduced to Turttle-1! We do not operate with arms up on hills. Ask how we learned... tippy tractors cause a lot seat pucker.
Yep - picking tractor seat cushion out of your rear is no fun.
   / Driving tractor with the front end loader bucket elevated . #74
Maybe mowing real tall stuff and don't want the bucket pushing it down. Perhaps better sightline - looking UNDER the bucket. OR they simply don't realize the increased dangers.
People mow with the bucket up for better view of what is it the tall grass. Also when cutting into a corner so that the bucket is up and out of the way. There is no danger mowing with the bucket up. I have been doing that for over 20 years. There might be a danger it you had a full load in the bucket or mowing on a steep side hill.
   / Driving tractor with the front end loader bucket elevated . #75
Also gives critters who might be lurking in your path a few extra seconds to get out.
   / Driving tractor with the front end loader bucket elevated . #76
Keeping the bucket low when shredding tends to fold over whatever you are mowing and loosen any seeds or chaff which immediately gets sucked into the radiator or rad screen.
I think it knocks it off before it can get in the screen.
   / Driving tractor with the front end loader bucket elevated . #77
I am wondering why some people do so
It's likely situational. But he best people to ask are the folks you see doing it that way. Good chance they'd know the answer.
   / Driving tractor with the front end loader bucket elevated . #78
I'm sure it also depends on your specific tractor and loader configuration.
On mine, when my bucket is hovering low above the ground, it is entirely below the line of sight over the hood. In other words, taking the bucket or loader off the tractor makes diddly squat difference for the visual angle to the ground in front of me. I'm sure others equipment would be different in that aspect.
Probably one of the reasons I've never wanted (or needed) to take the FEL off.
   / Driving tractor with the front end loader bucket elevated . #79
I have noticed some people driving there tractors with the front end loader bucket about 3' to 4'ft
off of the ground while mowing or brush hogging and I am wondering why some people do so . I always keep the bucket low to the ground .
I keep mine up because it makes it easier to see where I am going. Also, since my land is uneven at points, with sharp rises and dips, if I don't raise it up I can accidentally jam the FEL into the ground and dig out a big chunk of earth, or get it stuck and risk damage to the tractor. You only need this to happen once or twice to stop keeping the bucket low.
   / Driving tractor with the front end loader bucket elevated . #80
I mow for hire. Lot of repeat but always new customers and new lots/fields.
I never mow with the loader on. Not just the bucket, I remove the whole loader. The tractor feels like a whole different animal without the loader. Tight, nimble, no loader bouncing around, smoother ride, etc.
But questioning a 3' high loader.....seems to me thats just about normal transport height to me?
2014 Volkswagen Diesel Passat Sedan (A56859)
2014 Volkswagen...
206320 (A57192)
206320 (A57192)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
JOHN DEERE 4760 TRACTOR (A52708)
JOHN DEERE 4760...
