Driveway sensor
   / Driveway sensor #1
Wakey
Madison Georgia
John Deere Z915B Zero Turn 54 Deck
The only threads here are from around 2010 so I wanted to see what people are using now.
I need a sensor installed about 600 feet and a 2nd one about 300 feet. We have lots of deer and foxes etc so I'm guessing an electromagnetic sensor would be best.
In a perfect world smart phone notification would be ideal but those appear to be just entering the market.
I can go wired or wireless.
Thanks!
   / Driveway sensor #2
We installed a Dakota Alert DCPA-2500 ~ a year and a half ago. I enclosed the sensor in PVC and the lead to the sender in conduit though you don't have to. I also put a 12 volt strobe at my side of the bed so should someone come up the drive at night I should know for sure. It has worked perfectly and has not needed a battery replacement as of yet. There are other models / accessories available. The only con I see with the whole thing is that the control panel could be more intuitive. Want to erase zone light counts? press "c" for 2 seconds- not .5 seconds. That kind of thing.
   / Driveway sensor #3
I just checked the Dakota Alert site and didn't find one answer. How far can the unit transmit a signal? Looks like what I've been looking for.
I found an alternate site and my ?? has been answered.
   / Driveway sensor #4
   / Driveway sensor #6
I use Dakota Alert MURS. MAPs (buried electromagnetic sensor). Range can be up to a mile, even more. You may have to use a separate transmitter antenna for max range through thick woods. I'm powering mine with solar/controller and either a 12v auto battery (at gate) or a gel-cell in other spots.
   / Driveway sensor #7
Been using Dakota MURS units for many years after trying several far less effective and lasting ones.
Best system on the market IMHO. Range is miles.
   / Driveway sensor #8
I have a Dakota Alert MURS with two transmitters,one about 3/4 of a mile on the road to my business.
They work very well,use lithium batteries and they will last most of a year.
   / Driveway sensor #9
Is this to open a gate when you pull up?
Do you have secruity concerns with it opening to anyone?
   / Driveway sensor #10
I agree. I have an infrared type and it falses a lot.
A LOT. Squirrels, leaves blowing... Doesn't take much. I would not choose this kind again.
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
MT-500 Tack Trailer (A49461)
MT-500 Tack...
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
