Driveway sensor
   / Driveway sensor #1
Wakey
Madison Georgia
John Deere Z915B Zero Turn 54 Deck
The only threads here are from around 2010 so I wanted to see what people are using now.
I need a sensor installed about 600 feet and a 2nd one about 300 feet. We have lots of deer and foxes etc so I'm guessing an electromagnetic sensor would be best.
In a perfect world smart phone notification would be ideal but those appear to be just entering the market.
I can go wired or wireless.
Thanks!
   / Driveway sensor #2
We installed a Dakota Alert DCPA-2500 ~ a year and a half ago. I enclosed the sensor in PVC and the lead to the sender in conduit though you don't have to. I also put a 12 volt strobe at my side of the bed so should someone come up the drive at night I should know for sure. It has worked perfectly and has not needed a battery replacement as of yet. There are other models / accessories available. The only con I see with the whole thing is that the control panel could be more intuitive. Want to erase zone light counts? press "c" for 2 seconds- not .5 seconds. That kind of thing.
   / Driveway sensor #3
I just checked the Dakota Alert site and didn't find one answer. How far can the unit transmit a signal? Looks like what I've been looking for.
I found an alternate site and my ?? has been answered.
   / Driveway sensor #4
   / Driveway sensor #6
I use Dakota Alert MURS. MAPs (buried electromagnetic sensor). Range can be up to a mile, even more. You may have to use a separate transmitter antenna for max range through thick woods. I'm powering mine with solar/controller and either a 12v auto battery (at gate) or a gel-cell in other spots.
   / Driveway sensor #7
Been using Dakota MURS units for many years after trying several far less effective and lasting ones.
Best system on the market IMHO. Range is miles.
   / Driveway sensor #8
I have a Dakota Alert MURS with two transmitters,one about 3/4 of a mile on the road to my business.
They work very well,use lithium batteries and they will last most of a year.
   / Driveway sensor #9
Is this to open a gate when you pull up?
Do you have secruity concerns with it opening to anyone?
   / Driveway sensor #10
I agree. I have an infrared type and it falses a lot.
A LOT. Squirrels, leaves blowing... Doesn't take much. I would not choose this kind again.
71053 (A49346)
71053 (A49346)
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
3in Poly Pipe (A49461)
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
