Driveway Recommendations
/ Driveway Recommendations #11
Is there many that will tilt left/right to allow you to do that crown or are they done via the 3PL linkage
I think there are versions of both, but have never seen a rear blade that has a tilt function built-in.
A friend with a B7100 uses his T&T to tilt his rear blade. His particular blade does not tilt by itself.
The GlueGuy
/ Driveway Recommendations #12
Neil-
The manual tilt feature on the rear blade gives extreme angles, but coarse adjustments. This is great for pulling ditches, but for crowning and general leveling, the adjustment on the right side lift arm (whether manual or hydraulic) is usually enough.
<font color=green>stan</font color=green>
Thanks guys !
I'll look in earnest. I have that single ripper now, so I can rip a few passes, then use the back blade to cut any areas I need, or so I reckon anyhow.
Looks like a 4 or 5' blade is all mine will handle (L185 - L1501).
Cheers
<font color=blue>Neil from OZ.</font color=blue>
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
1988 Ford 8210 (A60462)
1988 Ford 8210...
2018 John Deere TX (A53317)
2018 John Deere TX...
CFG QK16R (A60463)
CFG QK16R (A60463)
Taylor Way 07012 (A60462)
Taylor Way 07012...
Giyi Gy-72Pro QA Mulcher (A60463)
Giyi Gy-72Pro QA...
