Driveway finishing
/ Driveway finishing #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
Finally I get to put on a top coat to my gravel driveway. Over the past 5 years I have probably spent several hundred dollars on shear pins for my snow blower because I only had 4" stone down. this afternoon I should be getting about 60ton of asphalt millings. Tomorrow I hope to get out there with the box blade and rear blade to spread it all out. Then I will put about 800lbs of concrete in the bucket, hook up the box blade with added weight and the roller to see if I can get it packed good enough for this winter.
/ Driveway finishing #2
I would like to see pics of this if you could.:thumbsup:
/ Driveway finishing #4
I would also like to see pics of this project. I am planning on using this method for 1 or possibly 2 driveways.....
/ Driveway finishing #5
Another vote for pics. I'm planning on doing this to my driveway end of next summer once the house is done.
/ Driveway finishing #6
i've heard....that a lil bit a diesel will soften up those millings and make em stick together!!
/ Driveway finishing #7
It sure will soften them up. In fact put on enough diesel and you end up with a pile of aggregate with no sign of the original asphateens. :thumbsup:
/ Driveway finishing #8
Egon is right. I worked for a paving company during summers in college and we would dip our flat faced shovels in diesel to keep the hot AC from sticking and at the batch plant, the drivers would spray diesel into the ten wheeler truck beds for the same results. The only thing that softens without harming the AC mix is heat.
So finally here are some pictures. Two of the first three loads were pretty chuncky but I did get them spread fairly well. THe guy I bought them form stopped by and noticed haw bad they were and asked if I would like a free load of fine stuff. Can't turn down free. So finally he was able to deliver some on Monday. Here is the final outcome.
Anyone have any experience using a vibratory roller on asphalt millings? I tried rolling this as best as I could but the tractor still leaves marks in the top layer. If I still had some warm summer left I would just leave it but I want it well packed by snow so I can run the snowblower over it. The rental place has 1.5 ton and 2 ton rollers any thoughts?
/ Driveway finishing #10
I ordered some "chunky" stuff to try and get it to hold on my hill, and the guy brought me fines...we went round a round a while, and he showed up with a vibratory roller on a big skid loader. It helped quite a bit, there's been very little washing since then...very little rain, but it looks good so far. If you do that, you have to have it perfectly level/even/smooth before rolling
When you say perfectly level/even/smooth, how perfect is perfect? It is smooth but it does have some gradual level issues. Spreading the top coat I moved it to the places where I needed it with the bucket then my wife raked it out by hand. I did drag a heavy pipe across to help on the leveling but it is not "perfect". I would have liked to run the back blade over it some but there is only about 1" of fines on the top and was worried about stirring things up and making a mess again.
/ Driveway finishing #12
As smooth as you'd like to have it forever...I didn't put in enough time, and there's some humps. I thought the roller would pack the high spots down more than it did and even things out...not so much.
2024 GMC Yukon Denali 4x4 SUV (A61574)
2024 GMC Yukon...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
2016 Volvo XC60 SUV (A61574)
2016 Volvo XC60...
John Deere AMT 600 5-Wheel Utility Cart (A61572)
John Deere AMT 600...
2020 Deere 50G (A64119)
2020 Deere 50G...
