confederatemule
- Joined
- Mar 30, 2009
- Messages
- 175
At what position is a rotary cutter gear box at it's furthest distance from the tractor out put pto shaft? I think my new shaft is too short.
Does it take you three hours to watch 60 Minutes?My Wallenstein chipper is my only PTO driven implement. I spent the better part of a day figuring out drive shaft length for the chipper. The time was spent trying to figure out all the various described methods of measurement. I must be REALLY dense but each described method gave me a different answer. Some didn't even make good sense!!! A whole lot of this confusion is because many of the explanations assume you have knowledge of certain facts.
I ended up doing it this way. Full connection of the chipper - minus the PTO shaft. Separate the shaft into its two parts. Connect half to the tractor PTO stub - other half to the chipper PTO stub. With my son running the tractor - he would raise/lower the rear 3-point while I held the two shafts - side by side.
This gave me the EXACT point where the chipper was closest to the tractor and how much needed to be trimmed off both shafts.
I ended up with a little over 12 inches of overlap and 3 inches of clearance before the shafts would touch either PTO universal joint( called bottoming out).
If it is brand new, then what is the length of the 2 shafts compared to each other? A new shaft is pretty long. But if the other shaft has been cut down you won’t get much overlap. From my experience rotary cutter pto shafts usually come very long. But if you bought a new shaft they come in different lengths for different applications. My snowblower pto is very short compared to my rotary Cutter. And I needed to cut my blower shaft even more. I got very lucky and found a brand new comer replacement slip clutch side for my rotary cutter on eBay. If was cheaper than buying replacement clutch discs for my current comer. It was super long brand new…At what position is a rotary cutter gear box at it's furthest distance from the tractor out put pto shaft? I think my new shaft is too short.
