Drive shaft replacement
/ Drive shaft replacement #1
Mhenderson
Tym 200
Does anybody have a video on how to replace a drive shaft from motor to hst on tym 200 or similar tractor
/ Drive shaft replacement #2
Edit: looks like this is a big issue on these tractors.
/ Drive shaft replacement #3
The root cause of the failure is the u-joints need lubricated, and TYM didn’t say to do it in any of the manuals or service bulletins. /The u-joint goes bad, and the vibration causes damage to other things.
/ Drive shaft replacement #4
I wish there was a video of the input shaft replacement as I'm about to attempt replacing mine if I can confirm the correct input driveshaft part # for a TYM T233 . The gray painted shaft in the photo is the same style broken shaft that is on my tractor now . My question is , will this newer style U joint shaft painted black fit the older T233 ? I read somewhere that TYM changed the shaft to the U joint style . Also the question is , is there clearance for the U joints and do you have to split the tractor to install it or is there room . New shaft part # looks to be 13182192100 if I can confirm it will fit . One dealer said it will work but I want a second opinion before I order it , wait weeks or months to get the part and have it being the wrong one . I would like to document this job with photos and videos to help others with this same problem . Any help is much appreciated !
/ Drive shaft replacement #5
On the T233, T273, and T293, which all have frames you don't have to "split" the tractor. That term is used for the non-frame tractors, and the engine/transmission are the longitudinal structure of the tractor. On the T233, you take off the hood, and pull the engine. At least, I think that is what the local independent tractor mechanic did when he replaced the drive shaft on my T233.
If you don't have the parts, service or operators manuals, and would like digital copies: Send me a private message and I should be able to send them to you.
/ Drive shaft replacement #6
When I replaced mine I cut a hole in the floor under the mat with a hole saw. That so I could get to the bolt on the drive shaft.
/ Drive shaft replacement #7
I did what Bud did. It's a very tight space underneath there and helps a lot to open up the top. It's in the center and covered by a black floormat so doesn't bother me any at all.
