DRIVE SHAFT LEAKING
/ DRIVE SHAFT LEAKING #1
warrior1942
yanmar 1700m
Jd 4400 frond end loader 4wd 2001
The front drive shaft is leaking fluid, the leak is directly above the power steering lines. If anyone has any suggestions on how to repair they would be greatly appreciated.
Thanks
/ DRIVE SHAFT LEAKING #2
:welcome:
Will look into that on the CD tech manual, if someone doesn't get back to you sooner.
I have the 4300 and am not sure where this fluid is coming from, but may be from the hyd. fluid cooler ahead of the radiator. Might check that out, and be sure the battery hasn't gassed the fins and caused corrosion and a leak. The distance between the battery and the fins are very close and if the battery isn't capped so the off-gas is tubed down below the battery, it can cause corrosion of these fins.
Thanks, will check that out. Where can I order a shop manual cd. Again thanks, any and all help is appreciated.
Thomas
/ DRIVE SHAFT LEAKING #4
Your Deere dealer to get the CD. Or on eBay if that is comfortable for you.
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
New - Front mount rototiller
New - Front mount...
2014 CHEVROLET 2500 SERVICE TRUCK (A64278)
2014 CHEVROLET...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
PAIR OF SPAN-ON RIMS (A64278)
PAIR OF SPAN-ON...
