Drip system timer/valve for low pressure?
/ Drip system timer/valve for low pressure? #1
sendero
Grayson County TX
Kioti DK35
This is a long shot, but I'm running out of ideas.
I've recently set up a water tank to provide irrigation for our garden plants (blackberries, blueberries a few grapes). The water tank is about 400 feet from our pond. I put in a 1.5" pvc line from the pond edge to the (1500 gal) tank. We fill the tank and then let it gravity feed our drip system. The tank is about 3 feet higher than our garden, and water flows freely through the 3/4" pvc output side and through the drippers.
After all the work of trenching, gluing and covering, I was happy to see it all work. I got out a timer that attaches to a water faucet and lets you water when on a schedule. But I wasn't prepared for the fact that the timers apparently depend on having water pressure to operate. One I tried never opens, the other never closes.
I've poked around the web and one company makes one of these hose timer gadgets that will operate on 5 PSI, but I'm' probably working with more like 2-3. I'd have to raise the tank 6 feet or so to get 5 PSI, and given what 1500 gallons of water weighs, that's not really an option.
I'm wondering if all electric valves, such as the ones used in sprinlker systems, require pressure to work. I'm trying to find some way to water on a schedule, since I'm not there most of the time.
Anyone have any ideas?????
/ Drip system timer/valve for low pressure? #2
I've bought from these folks before.
Drip Store
/ Drip system timer/valve for low pressure? #3
I have no experience with this, but I will throw out some thoughts. I assume 120 AC is not available. Have you considered something like a 12 volt DC deep-cycle car/motorcycle battery to run a solenoid valve(on/off) or even a 12 volt DC water pump(Harbor Freight) that would increase the pressure so your timers would work. Maybe a solar charger to keep that battery charged up. Theses ideas are probably not that easy, but I was just trying to "think outside the box" a little.
/ Drip system timer/valve for low pressure? #4
You didn't say how you fill your 1500 gallon tank through the 1.5" line. Is it pumped? Gravity? Is there any chance you can control the filling side instead of the drain side? ...something like letting the tank fill up as a sump and drain out through your distribution 3/4" system at the same time the sump is filling.
Perhaps you just want to fill the sump and then drain out 300 gallons or so each day thereafter when you aren't there with no power applied. I think that or something similar is what you are saying and that won't work by controlling the input as I am suggesting.:confused:
/ Drip system timer/valve for low pressure? #5
I thought it was 2.2psi per foot of head?
Am I wrong?
at 5', you should be at 10psi or so, and relaly it's to the top of the tank
Most irrigation/sprinkler valves need 30 to 40psi to run right.
Try a plumbing supply store, there have to be timed valves that open more like a ball valve, than a sprinkler valve.
/ Drip system timer/valve for low pressure? #6
Am I wrong?
2.33 feet gives 1 psi. I have yet to see a solenoid valve that does not operate on some water pressure. I have a faucet connection type that uses 4 C cells and actually rotates a ball valve which would work. I forgot the name brand, but look for something like that.
/ Drip system timer/valve for low pressure? #7
I have had good luck using Melnor timers, believe it is model 3060, uses two AA batteries that last all summer, motor-driven valve vs. water pressure/pilot control, so no minimum water pressure issues. Bought at Home Depot....but can't remember price.
RavensRoost
/ Drip system timer/valve for low pressure? #8
You need a MOV (motor operated valve) or a AOV (air operated). Just a cheap pvc ball valve and mount a 12V window motor or this windshield wiper motor over it. I'd buy a 1" ball for stoutness and sleeve it down to the pipe size you need.
Surplus Center Item Detail
That's pretty much how we control RCW (reactor coolant water) at the nuke plant cept we use a bigger window motor.
/ Drip system timer/valve for low pressure? #11
"if 120v is available" a valve from an ice maker, dish washer, or washing machine, are all cheap, work, and last a long time. i've used them for all sorts of things without a single problem. rainbird sprinkler system valves don't seem to last very long, and seem to like to fail in the open position.
heehaw
/ Drip system timer/valve for low pressure? #12
On the Melnor 3060, looks like they may have "improved" it. (I have the older units, work fine.) Here is a paste of customer review on Amazon:
" New 3060 different from old 3060, July 27, 2006
Reviewer: San Antonian "Al" (San Antonio, TX) - See all my reviews
Melnor completely changed the model 3060 this year. I had had old models for 9 years. Loved them. Had to replace 2 this year. They are completely different, less features, no manual/auto with valve on/off feature. And worse, the clocks change time! My old ones chugged along with absolutely no problems for years. The new ones have failed in the first week!
Not only that, they are harder to program.
Ignore all the good review that are pre-2006! They don't apply to this model."
RavensRoost
/ Drip system timer/valve for low pressure? #13
heehaw
When use water that is not clean, the dirt in the water will eventually clog the very fine screen on most any 24V solenoid water operated valve. They make dirty water valves with a scrubbing action to eliminate that. In this guys case, a simple battery operated motor/gear operated open/close timer valve like the Melnor is the simplest, easiest way to go. They do not cost much. Rarely is dirty water much of a problem for the valve. The drip system however is another matter.
Thanks for the ideas guys. To answer some of the questions that have come up...
I use a gasoline powered portable pump to pump water from the pond to the tank. It has to go about 15 feet uphill, so it takes about 35 minutes to fill the tank.
A foot of elevation equals .43 lbs of pressure. Raising the tank just really is not an option, since it would weigh over 6 tons when full.
I don't have 120V out there and don't really want to mess with that. Battery power is a possibility, probably a likelihood.
I was thinking I could perhaps use the timer portion of the hose timer to power a relay that controlled a suitable valve. I'm not sure where to get said value, though some suggestions here look promising.
/ Drip system timer/valve for low pressure? #15
Billy, heres a good link. Irrigation Pumps & Alternate Water Sources
/ Drip system timer/valve for low pressure? #16
I don't know if this helps, but Orbit makes a 3AA battery powered digital timer that will expand to up to 4 zones but generally only comes with 2. It can be programed for multiple waterings per zone per day. They cost about 40.00.
I use 2 to water my orchard and grass/plants. I use a plastic backflow preventer/vac breaker on each zone because vacuum can cause the valve to not operate. Perhaps that is what is causing your problem. They are also only good for 1 impulse sprinkler per zone because of the size of the valve. It is standard hose bib fittings. I generally Y off the vac breaker and run a low flow drip system with an impulsesprinkler too.
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2019 PETERBILT 567 TRI/A DUMP TRUCK (A59912)
2019 PETERBILT 567...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59912)
2023 UTILITY VS2RA...
2012 Generac QT04854 Anax Quiet Source 58kW Natural Gas Generator (A61572)
2012 Generac...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
