Drilling steel.
/ Drilling steel. #31
As i have done in the past . Scribe your circle with your plug as a guide . Use a 3/16 drill bit and drill holes just to the inside of the scribed line and as close as you can to each other. A hole that big will take 10-15 minutes to complete . knock the centre out . A quick cleanup of the hole and your ready to weld the plug in , the weld will cover any little notches without a sign of them being there . Almost impossible to create a spark especially if you use some soluble oil mixed with water whilst drilling . If you use a hole saw be sure to drill the pilot hole first . If you do'nt , when you learch forward when the hole saw drill breaks through the teeth on the saw will grab and you will brake the pilot drill every time .
/ Drilling steel. #32
So in a related question.....how would I drill a 1-1/4" hole in 1/4" steel plate that is covering my well opening? Simple hole saw? Also, this is out in the middle of a field with no power source. Will a portable drill have enough umph to cut this one hole?
THX
/ Drilling steel. #33
THX
High quality new holesaw, and my 18V dewalt cordless or my 19v Craftsman and a couple batteries.
Take you longer to set up and get going then to do the actual drilling.
Hi quality, sharp (new) bi-metal bit will make it go easy.
/ Drilling steel. #34
Thanks Al. I did not want to pull the cover and bring it into town to drill. Safety issue leaving the well exposed, etc... Will give the battery packs a work out now.
/ Drilling steel. #35
Maybe a portable generator or an inverter for your tractor,truck, vehicle and an electric drill.
1770 (A58375)
1770 (A58375)
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
Kubota L4701 (A53317)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
