Drill Press for BIY projects
/ Drill Press for BIY projects #1
lhfarm
Central Indiana
NH TC40DA
My $25 farm sale over-seas bench drill press died in the middle of my latest project. I don't do lots of projects, so I don't need an industrial model. Just need something to drill holes in thick metal now and then. I stopped by Sears and they have their 12" bench top and 15" floor models on sell. Are there advantages to having a big floor model? What would be a good setup for the types of projects found here?
Thanks,
/ Drill Press for BIY projects #2
Thanks,
Probably the biggest advantage of a floor model is the ability to run a tubeing notcher and also be able to drill holes in the end of longer objects... I have a 1/2HP fairly large drillpress that is a bench version(got a screaming deal on it surplus). I am looking for the pipe assembly to convert it to a floor model for these 2 reasons.
/ Drill Press for BIY projects #3
Barry,
I had an imported drill press that seemed to have the speeds setup for wood rather than metal. For regular drill bits in mild steel, 100 surface feet/minute (with lubrication) should be about tops for good drill bit life. That translates into about 750 RPM for a 1/2" drill bit, 1500 RPM for a 1/4", and 375 for a 1" drill bit. The next most important thing to me is chuck runout. Put a shaft in the chuck, turn it on slow, and see how much it wobbles.
John
/ Drill Press for BIY projects #4
I have had the 15" Sears floor model for about three years now, it has drilled many holes in 1/2" plate.
The floor model type is all I have ever used at any place I have worked so that's what I got and it works for what I do with it.
Also if your bench space is limited then the floor model doesn't take up much floor space.
/ Drill Press for BIY projects #5
Depending on needs and set up, the bench model can always go sit on the shelf for a while and not take up any space at all, unless not enough shelves. I would vote for bench with some way of securing to the bench.
/ Drill Press for BIY projects #6
I have been using a Harbor Freight Floor model drill press, the 16 speed green one for over 15 years with no problems. I don't run a machine shop but I do drill metal way more than wood with it. You can stall it (slip the belts or stall the motor) if you feed a large bit too fast. I drill holes up to 1 inch in metal over 1/4 inch thick. Above that diameter I lean toward my plasma cutter. It will drill much thicker metal if you take your time and use good cutting fluid, I just don't have need to do it often.
My wife won a continuously variable speed bench model Delta drill press as a door prize, It is a really nice bench top model. I use it about once for every several hundred times I use my HF unit. Sometimes for convenience when two setups are really handy I use it but it goes unused for months at a time.
Pat
/ Drill Press for BIY projects #7
I'm with Pat. I have an old 16 sp HF floor model that I've drilled many,many holes with. It isn't a precision or production model, but I have drilled many 1" holes in 1" thick metal and drilled 4" holes with a hole saw. I can slip the belts and the chuck has come loose on occassion, but for the 149.95 I paid for it, well worth the money.Later, Nat
/ Drill Press for BIY projects #8
I have a sears floor model next time I will buy a harbor freight one of higher quality.........Larry
/ Drill Press for BIY projects #9
bench model costs a lot less.
floor model generally has less run-out on the chuck and a bigger motor/more speeds.
floor model can handle taller objects and larger drill bits.
bench model costs a lot less ($60-$99 depending on if you go HF or name brand) and if you bolt the base to the edge of your workbench, you can turn the head backwards on the stand so it can double as a light duty floor model.
with that said, if you have the funds and floor space, you would likely find the versatility of the floor model worth the extra $$.
/ Drill Press for BIY projects #10
i looked for a chineese benchtop with as many speeds as i could find.... found me like a 18 spd .... the belt setup needed work, but i make it work for me.... i can get it down to some really low speeds for drilling large holes in steel.
/ Drill Press for BIY projects #12
I have a Jet 16-speed floor model that I've owned since the mid 1990's. I'm pleased with it and I've cut 3-1/2" diameter holes in 1/2" plate with it using a hole saw. Granted, that is out of the normal range of the machine and even at 200RPM, the hole saw was going about 3x that it should have. But the Jet got it done with time, patience, cutting oil and ear protection. The Jet has a far superior depth control setting than the Sears and Delta units.
If you get a floor model regardless of brand...BOLT IT TO THE FLOOR! Drill presses are inherently top heavy.
/ Drill Press for BIY projects #13
I hope HF has improved their cheapest drill press since I got one 20 years ago.
It claims 1/3 hp, but it couldn't be half that. No power at all.
Not Recommended, unless someone reports that the current model is much improved.
/ Drill Press for BIY projects #14
I have that old '50's vintage Craftsman floor model that everybody's father and grandfather had. They must have built millions of them; I still see them all over the place. It has primarily wood working speeds with 750RPM being the slowest. I've used it over 30 years (yikes! I'M that grandfather!). I have always wanted to rig a way to slow it down.
A friend took one and built an auxiliary jackshaft with another 4 step pulley on it but he had to cut away part of the casting to get the belts to fit. Too radical for me. Anybody have other ideas?
I'm doing more metalworking these days and lately I've thought of a 2:1 or 3:1 gear reduction and re-mount the motor lower. Ive also thought of trying to mount my big vari-speed Milwaukee drill motor on the drill press. Now that my house construction is done that hand drill does not see much work.
One of the features I'd look for in a new press (besides slow speeds for metalworking) is a good, easy-to-use depth adjuster. The old Craftsman has a superior one and I'm now spoiled.
/ Drill Press for BIY projects #15
Schism has the idea, for metal work look for the slower speeds available.
RedDirt, what is the Motor speed on your old craftsman?
You might luck out and be able to change for a slower motor.
If it is a 3200 rpm motor, you can swap it for 1725 rpm motor.
That's darn near a 2:1 reduction.
I have a Bridgewood floor model, it's about 25 years old. I can get down to about 230rpm on the lowest pulley setting, but it still could use a little lower speed for the larger bits.
/ Drill Press for BIY projects #16
If a floor model is desired and economical cost is important, the drill press at TSC is $139. I bought it and it works well for average projects. Slowest speed is 260rpm's and worked well for me drilling 1" holes in 3/4" plate. I was using some liquid wrench spray for cutting oil.
/ Drill Press for BIY projects #17
/ Drill Press for BIY projects #18
Aquaman said:
She got a sister?:D :D :D
Yes, she does and the sister is on hubby #2 AND you DO NOT want to be #3, trust me.
...and now for the rest of the story...
So much for name brand vs HF! The continuously variable speed Delta bench top drill press uses variable diameter pulleys which you adjust while it is running with a convenient control. A great system when done correctly. They didn't get it right. It came apart during the first few operations. I put it together and it came apart again. I re-engineered it and it worked OK. I called Delta and they were savvy to the problem and sent me a new variable pulley assy, a new belt, and various little parts (for free.) I took out my mods and installed their new improved and lemon scented assy. It works like it is supposed to now.
It does not go as slow as the HF at the low end of the adjustment. It is not good for big holes in heavy metal. The routine oiling (called out for daily maint) requires R&R of 6 sheet metal screws. I drilled a hole in the top cover and drip oil in and put a plug in the hole to keep out debris.
The HF could use more power. The chuck comes off way less than with the Delta. I could use a lower speed once in a while but it isn't too bad. I would not recommend the fancy Delta bench top over the HF Chinese unit.
After I expand my shop by enclosing a 48x21 foot shed on the side of it and separate the metal working from wood working I will get a lot more use out of the Delta as I will assign it to the wood shop to save walking out into the metal shop which may not be heated if I'm not doing much out there. I know there will still be times when I will have to take something to the HF drill press because of size and when I need low speed.
I think the HF has been a terrific bargain. It has performed pretty good, no maint problems, and it is still doing fine after about 15 years. I would not hesitate to buy another if the need arose. If you are going to be doing super high precision work and normally use measuring devices with calibrations traceable back to the national Bureau of Standards (Now NIST National Institute of Standards and Technology) then you need to avoid HF and buy a high quality precision machine. If you are super impatient and need big holes in thick steel RIGHT NOW then maybe you need something larger, more robust, and with a larger motor. (Or a powerful industrial laser.)
Pat
/ Drill Press for BIY projects #19
I have a 3/4 hp, 16 speed floor model made in Taiwan. Lowest speed is 170 rpm. I've had it for about 20 years. (Holy crap, I'm gettin' old.)
One problem I've had that nobody else seems to have is the stroke is too short, just a little over 3 inches. The depth stop isn't the best setup either.
Just something else to consider.
Andy
/ Drill Press for BIY projects #20
Skunk,
That would be too easy! Unfortunately it is already 1725, 1/2HP.
I've looked at reduction gear boxes at Surplus Center but they don't seem to have a well suited box for my needs. I may do a web search for different selection. Anybody have suggestions where to look? I'd like a straight line box at 4:1 reduction with 1/2" or 5/8" keyed shafts rated at 1/2 to 1HP.
I checked my existing slow speed with a digital tach and found it is now 670rpm so a 4:1 would give me 160rpm.
TOYOTA 5K FORK LIFT (A67714)
TOYOTA 5K FORK...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
PORTA POTTY (A68842)
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2011 FORD F-250 SUPER DUTY (A67714)
2011 FORD F-250...
2016 Ford F-450 Liftmoore 2550 5,000lb. Crane Service Truck (A66736)
2016 Ford F-450...
