DrawbarQuestion for BX2200
/ DrawbarQuestion for BX2200 #11
Good idea, cheap, looks great...Great job!!!
Now paint some little tractor scenes on it/forums/images/graemlins/grin.gif
/ DrawbarQuestion for BX2200 #12
Phil,
Congrats on your new BX!
I mounted three upright pieces of pipe on my drawbar and stacked barbell weights on them. The pieces of pipe are locked onto the drawbar with set collars. I then slid one end of my adjustable top link onto the top of the middle piece of pipe to stabilize the rig. I bought my used plastic coated barbell weights at a local St Vincent DePaul store(like Goodwill). They were very cheap. Earlier I tried hooking a heavy lead weight onto the 3 pt,it worked, however it was difficult to get off and on and it was very tough on my back. Barbell weights are much easier to take on and off. I have been using this set up with my front blower this winter and will probably use it with my FEL in the spring.....
Dan
Dan,
Thanks for the reply. Sounds like a good idea. What is a "set collar" that you mounted the uprights with?
Phil
/ DrawbarQuestion for BX2200 #14
Set collars are steel collars that you slide over a shaft. They have a set screw on the side to lock them on the shaft or in this case pipe. I replaced the set screws with thumb screws so that I did not have to use an allen wrench to take them off. Seems I am always losing allen wrenches and cant find the right size when I need them.....
Good luck!
Giyi RB66 Quick Attach 66" Rock Bucket (A60463)
Giyi RB66 Quick...
Qty 4 Wascomat 100lbs Dryer (A59317)
Qty 4 Wascomat...
Adams Tilt Trailer (A61307)
Adams Tilt Trailer...
AGT Industrial SSECAG-Y QA Auger w/ Bits (A60463)
AGT Industrial...
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
