drawbar meets rotary cutter.
/ drawbar meets rotary cutter. #1
lawn_king
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
Yes i am a knucklehead! Somehow, hogging a field i know inside & out, i managed to drop and run over my drawbar with the rotary cutter!
/ drawbar meets rotary cutter. #2
Post a picture!!!!!!!!
Bob
I noticed a semi square dent in the back of the rotary cutter when i was washing it down, the next morning i removed the rotary cutter to mount up the core aerator & i noticed my drawbar was missing. I returned to the feild and after a half hour of sniffing around i found it! I will post a photo of it this weekend. Hats off to landpride, i cant believe i did not break a blade!
/ drawbar meets rotary cutter. #4
Rotary cutters are almost indestructable. I ran over a large, large rock the other day while the neighbor was watching and waving with her toddler (from a good distance). You know the sound it makes. She looked like she was going to call 911, but the mower powered right back up and kept on going.
/ drawbar meets rotary cutter. #5
lawn_king said:
I noticed a semi square dent in the back of the rotary cutter when i was washing it down...
You didn't hear it?
Even with my hearing protection, I know when I hit something because it usually makes a pretty good bang. Just touch up the blad with a grinder.
/ drawbar meets rotary cutter. #6
Shimon said:
You didn't hear it?
Lawn King had his AC on high and listening to tunes on the radio!!! He's got a cab!!! Sorry Lawn King, had to tease you a little. Out of pure jealousy you understand!!! :)
I did hear it, i thought it was rock or brick, never would have guessed i had just ran over my drawbar. I did have the ac on and the tunes going. Factory cabs are great, but you do loose that special bond you feel to the land working open station. I worked open station tractors from 1978 to 2001. I was core aerating 5 acres of youth soccer fields in the fall of 2001, the sky opened up & poured rain, killed my cell phone and wallet! That was it for me, i called my dealer the next day and ordered a curtis cab for my B7500.
/ drawbar meets rotary cutter. #8
Earlier this spring I was tooling along with my 6' KK. All of the sudden I hit something which bogged down momentarily. I looked back and a small white tail deer was still in the air. Bambi meets Kubota. Totally shredded the little critter.
Oh yes one other true story thats actually true. Last year my ancient Woods Dixie Cutter 5' (being pulled by an 8N Ford) launched a piece of quartz about the size of a a canteloupe at least 30 yards right through my barn. Left a pretty clean hole.
Rotary cutters are effective but they scare me to death.
ds
/ drawbar meets rotary cutter. #9
A friend of mine had his $250 String Trimmer in his loader and did not notice that a tree knocked it out when he was backing up. He then proceeded to run over it with the Bush Hog. The Bush Hot won.
/ drawbar meets rotary cutter. #10
ds
I've ran quite a few deer, woodchucks, pheasants, quail, rabbits untold number of mice and snakes through my mowing machine while making hay. Interesting thing is that when you come back the next day, they are gone..........:D
/ drawbar meets rotary cutter. #11
My neighbor broke the blade on his 6' Bush Hog on Friday. It broke right at the pivot eye right after he had started up - not while cutting. Luckily it caught the back edge of the cover on the way out and didn't fly far. The break on one side was rusted so it had cracked some time ago. The back edge had a spot that looked pretty well hammered where the blades apparently clack together on startup. The PTO clutch on those Fords can engage pretty sharply. The other blade was less hammered and there were no cracks. Thinking about balance I recommended 2 new blades and that's what he got. Actually the style was slightly different so there was no question of using a new-old combination. The blade set that broke were a replacement set. The new ones were OEM.
Brad
/ drawbar meets rotary cutter. #12
Y'all know its funnier when he tells you this on the phone. You an't the only one that has done that. Lucky me, I only scooped mine up with my box scraper.
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
Flex King KM 7 Section V Plow (A63688)
Flex King KM 7...
2022 EZ-GO ELITE...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2003 Ford F-350 Flatbed Sprayer Truck (A61573)
2003 Ford F-350...
