Drawbar hookup
/ Drawbar hookup #1
sunspot
Rural Birmingham, AL
Ford 3910 86'
A new guy question.
What is used to attach a chain to the drawbar? I was thinking to use a bolt type anchor shackle and a top bar pin for easy removal.
See All-Lifts, Inc.Shackles and rigging hardware
I know from a safety aspect, not to pull from the lift arms but I'm not sure on what's used to go in the drawbar hole.
/ Drawbar hookup #2
That should work. I use a clevis similar to this one that I bought at my tractor
dealer for around $10.00
/ Drawbar hookup #3
I have a trailer hitch ball... put chain around it and hook end of chain back on itself. Easy on, easy off. Chain weight keeps it from getting loose.
/ Drawbar hookup #6
Same here.
/ Drawbar hookup
Thanks guys. I was doing a search on clevis when I found that rigging web site. I had also thought of using a hitch ball but I値l go with the clevis hookup.
/ Drawbar hookup #8
I use a clevis as the others for chaining down and transporting, but I use a drawbar hook just like workinallthetime posted for pulling. The clevis would work for pulling, but you lose the advantage of grabbing the chain wherever you want/need to unless you run it though and back to itself...
/ Drawbar hookup #10
sunspot said:
A new guy question.
Clevis and chain hooks work for me.
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
SWACARS 20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
SWACARS 20' SINGLE...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
