Drawbar hookup
/ Drawbar hookup #1
sunspot
Rural Birmingham, AL
Ford 3910 86'
A new guy question.
What is used to attach a chain to the drawbar? I was thinking to use a bolt type anchor shackle and a top bar pin for easy removal.
See All-Lifts, Inc.Shackles and rigging hardware
I know from a safety aspect, not to pull from the lift arms but I'm not sure on what's used to go in the drawbar hole.
/ Drawbar hookup #2
That should work. I use a clevis similar to this one that I bought at my tractor
dealer for around $10.00
/ Drawbar hookup #3
I have a trailer hitch ball... put chain around it and hook end of chain back on itself. Easy on, easy off. Chain weight keeps it from getting loose.
/ Drawbar hookup #6
Same here.
/ Drawbar hookup
Thanks guys. I was doing a search on clevis when I found that rigging web site. I had also thought of using a hitch ball but I値l go with the clevis hookup.
/ Drawbar hookup #8
I use a clevis as the others for chaining down and transporting, but I use a drawbar hook just like workinallthetime posted for pulling. The clevis would work for pulling, but you lose the advantage of grabbing the chain wherever you want/need to unless you run it though and back to itself...
/ Drawbar hookup #10
sunspot said:
A new guy question.
Clevis and chain hooks work for me.
2025 Swict 72in Bucket Skid Steer Attachment (A59228)
2025 Swict 72in...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2004 International 4300 Bucket Truck (A60352)
2004 International...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A59228)
2025 BrushFox...
