Drawbar hookup
/ Drawbar hookup #1
sunspot
Rural Birmingham, AL
Ford 3910 86'
A new guy question.
What is used to attach a chain to the drawbar? I was thinking to use a bolt type anchor shackle and a top bar pin for easy removal.
See All-Lifts, Inc.Shackles and rigging hardware
I know from a safety aspect, not to pull from the lift arms but I'm not sure on what's used to go in the drawbar hole.
/ Drawbar hookup #2
That should work. I use a clevis similar to this one that I bought at my tractor
dealer for around $10.00
/ Drawbar hookup #3
I have a trailer hitch ball... put chain around it and hook end of chain back on itself. Easy on, easy off. Chain weight keeps it from getting loose.
/ Drawbar hookup #6
Same here.
/ Drawbar hookup
Thanks guys. I was doing a search on clevis when I found that rigging web site. I had also thought of using a hitch ball but I値l go with the clevis hookup.
/ Drawbar hookup #8
I use a clevis as the others for chaining down and transporting, but I use a drawbar hook just like workinallthetime posted for pulling. The clevis would work for pulling, but you lose the advantage of grabbing the chain wherever you want/need to unless you run it though and back to itself...
/ Drawbar hookup #10
sunspot said:
A new guy question.
Clevis and chain hooks work for me.
/ Drawbar hookup #11
Me, too, but identify that tractor for me, Flusher, because I don't recognize it. Is that an old Ford without the hood? Whatever it is, it sure looks neat and clean.
/ Drawbar hookup #14
looks like a 135 massy to me, had a 175 at one time, that thing would lift small houses i swear
/ Drawbar hookup #15
It's my 1964 MF-135 diesel still being restored. Just don't have the sheet metal on it yet. It's an orchard tractor that has those wide, squat rears.
I need to replace the vertical exhaust stack since there's an interference with the hood sheet metal. Need to reroute the fuel line to the injector to get this problem solved. Haven't gotten around to that fix yet. Maybe next month.
/ Drawbar hookup #16
One thing that I'd want to do is to have something behind me in case the chain snaps. My father once pulled our 1957 Olds with a chain. Chain snapped and wrapped back onto the hood of the car. Could have easily snapped and wrapped back to the back of my father on the tractor.
If you have ROPS, attach a piece of plywood between the ROPS?
Ralph
/ Drawbar hookup #17
Ralph
That has happen to me when pull brush/vines/trees out before. Not very smart on my part.
/ Drawbar hookup #18
Hmmm.
Porno on TractorByNet.
A topless tractor.
Such a sad lack of morals
2017 Nissan Rogue SUV (A59231)
2017 Nissan Rogue...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
Gravely Pro Turn 460 60in. Zero Turn Commercial Mower (A59228)
Gravely Pro Turn...
