Dramas with 5515
/ Dramas with 5515 #1
Not workin
Queensland
John Deere 5515
Hi I have a 2008 John Deere 5515, done 2220hrs, and ever since purchase I have had intermittent faults with transmission. Before starting display will show NrSe fault code (sometimes) and if it does start will show NrCE and NrOE (sometimes), this will not allow you to drive. Sometimes will just start and drive, but also has brought up the NrOE fault while working the machine. This can be dangerous as you lose all drive and the tractor just free wheels. Have had John Deere and independent mechanics look at this problem and all have no idea. The John Deere boys left telling me to give the solenoid block for the transmission " a few taps with a hammer", so much for paying for expertise. Have spent quite a bit and am quite upset as first time John Deere buyer. Everybody told me John Deere were great for reliability and service but after 2 years trying to resolve the problem, I have found the complete opposite. Am trying to sort this out myself but drawings and schematics are difficult to get. Was hoping somebody could help me with some information pertaining to the shut off valve and pressure switches involved with it. Have checked the shut off valve solenoid and seems to be working when 12volts is applied to it. It seems to be getting only 6 volts from the EHM and I am wondering if maybe there is a dodgy pressure switch or maybe faulty contact inside the EHM unit???? Am trying to get a hydraulic and electrical schematic or line diagram of this system. Can anybody help me please.
/ Dramas with 5515 #2
you need a manual for specs to calibrate the sensors and they work off of up to 6 volts , chances are you damaged something putting12 volts to it,
Mercury Outboard Boat Motor (A66738)
Mercury Outboard...
YALE FORKLIFT (A63291)
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
More Info coming soon (A64557)
More Info coming...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 FREIGHTLINER...
