Drain plug radiator- YM1510D
/ Drain plug radiator- YM1510D #1
Jjpbe
Yanmar 1510D / Kubota L245/ Toro 223D
Hi
Can someone tell me the location of the drain plug for the radiator on the YM1510D.
I would like to flush the coolant system and change the fluid.
Thank you very much,
Jjp
Thank you Aaron.
What about the drain plugs for the front axle. I believe there should be one in the bottom of both outer gearbox units. I only see one on the bottom in the middle of the axle
Where is the location of the drain plugs for the transmission-hydraulic oil? Thanks.
Jjp
Thank you Winston.
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
PITTSBURG 2R CULTIVATOR (A63291)
PITTSBURG 2R...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
