drain plug for hydraulics
   / drain plug for hydraulics #1
swamperkk
gonzales,la
ford 1700
i have a ford 1700 4x4 tractor,i want to drain my hydraulics,there is a bolt under the axle that holds the oil,but i dont think its use to drain the hydraulics,there is one for the transmition,i hate to take it off and its not the hydraulics,does anybody have a picture that would help me?
   / drain plug for hydraulics #2
On 99% of tractors the transmission is the hydraulic sump. So hydraulic fluid is the transmission fluid. Often drains in multiple places to get various low spots like final drives on the rear axle in addition to the main drain.
ok,thanks,i was wondering why there is a drain plug under the transmission and one under the rear axle of my tractor,now trying to take off the 15/16 bolt that holds the screen filter so i can change it,hope its not the pump!!!!
   / drain plug for hydraulics #4
A Screen Filter is not a Pump.
What are you trying to achieve? Routine servicing oil & filter change? Or do you have a hydraulic problem?
Screens are cleanable. Filters are replaced.
Drain the oil before you pull the screen.
15/16" is a big bolt for holding a screen.
Can you post pics (and do you have a 'full stop' key)?
my hydraulic not picking up,very slow then it stops,now it wont pick up,i'm hoping its my screen my question is i have two drain plugs,one under the transmission and one under the rear axle,thought it was another tank jus t for hydraulics,first time doing this,wanted to be sure not to mess up,i know about the screen just wanted to see if thats my problem,never took it off. its takes a impact to get this off
got another question,what is a full stop key? new to this
   / drain plug for hydraulics #7
The description fits the symptoms of a partially blocked suction screen. You should not need an Impact Gun to remove the Suction screen on any tractor.:eek:
Drain both Trans and Rear axle. Inspect the oil for water ('Creamy/Milky' colour?) and 'Glitter'. Also, check the screen for metal debris .
A "Full Stop" (You may call it a "Period" ?) divides your writing into coherent 'sentences'. <There's one!
have to use a impact just to loosing the bolt not all the way,drain the oil,the oil looks pretty clean haven't remove the screen yet,i will give u a update,
   / drain plug for hydraulics #10
The oil dribbling in the bottom of your container is a pretty ugly colour. So is the screen. How clean did you get it?
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
YANMAR YT359 TRACTOR (A51247)
YANMAR YT359...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
UNUSED INDUSTRIAS AMERICA L6 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
