drain plug (crankcase) torque value
/ drain plug (crankcase) torque value #1
tmar04
YM 276
Got a drippy drain plug and have replaced the copper sealing washer but still drips. What is the recommended limit for tightening this plug? thanks to all.
/ drain plug (crankcase) torque value #2
Coat the threads with hi-temp silicone sealant, carried by all autoparts stores.
/ drain plug (crankcase) torque value #3
35#'s if I remember correctly. I always use a new washer and give it a small bead of sealant, (**** retentive I know). But I've never had a leak.
/ drain plug (crankcase) torque value #4
There's an o-ring on mine in a groove at the top of the threads, and there is a corresponding groove in the pan for it to fit into. I just give it a good tug with a 3/8 ratchet, maybe 25 ft lbs?
I see in the parts book a 'packing' was used on the earlier series.
Possibly you could use the later drain plug and o-ring.
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
24in pin on excavator tooth bucket (A61307)
24in pin on...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
2021 Takeuchi TL6R (A64126)
2021 Takeuchi TL6R...
Pro Tech HD Grapple (A65563)
Pro Tech HD...
2011 Ford Expedition SUV (A64557)
2011 Ford...
