drain plug (crankcase) torque value
/ drain plug (crankcase) torque value #1
tmar04
YM 276
Got a drippy drain plug and have replaced the copper sealing washer but still drips. What is the recommended limit for tightening this plug? thanks to all.
/ drain plug (crankcase) torque value #2
Coat the threads with hi-temp silicone sealant, carried by all autoparts stores.
/ drain plug (crankcase) torque value #3
35#'s if I remember correctly. I always use a new washer and give it a small bead of sealant, (**** retentive I know). But I've never had a leak.
/ drain plug (crankcase) torque value #4
There's an o-ring on mine in a groove at the top of the threads, and there is a corresponding groove in the pan for it to fit into. I just give it a good tug with a 3/8 ratchet, maybe 25 ft lbs?
I see in the parts book a 'packing' was used on the earlier series.
Possibly you could use the later drain plug and o-ring.
Bobcat T650 (A64126)
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
2003 Kenworth T800 Log Truck (A62679)
2003 Kenworth T800...
(60) SDlanch High End Ratchet Tie Downs (A64127)
(60) SDlanch High...
2009 Kubota M108S (A64126)
2009 Kubota M108S...
