Drain plug 3/8 +/-
/ Drain plug 3/8 +/- #1
marhar
Denton NC
Farm Trac 60
I have a lawn tractor that has a 3/8" square drain plug (it is a little bigger than 3/8 I cannot put a 3/8 ext bar on it). It is a very tight spot to get a wrench on it. Now I take a 1/2" ext bar and put a wrench on the drive end to turn the plug. The 1/2 is a little "sloppy". Any ideas?
/ Drain plug 3/8 +/- #2
Is the square part male or female? If male you might be able to find a 12 point socket to fit. There are 8 point sockets made for those.
It is male.
/ Drain plug 3/8 +/- #5
You didn't say what this is. 3/8" pipe size or head size? Possible that it is a 10 MM or 7/16" ? Evac it through the dipstick or drain via the filter are other possibilities.
/ Drain plug 3/8 +/- #6
i have seldom seen any square head that was a exact size. especially on a pipe plug which most drain plugs are.
if you have room to get a socket on it try metric as well. there should be some size that will grip it. same with wrenches. on both try 6 or 12 point.
also have used a large vice-grip and small pipe wrench.
/ Drain plug 3/8 +/- #8
most pipe plugs the square is also tapered a little which makes a standard open end wrench fit even worse. I have a 3/8" 8 point socket that is meant for square heads and works most of the time. Seems like some of the newer plugs are more of an oddball size that older ones.
/ Drain plug 3/8 +/- #10
Since it sounds like it is doable but not easy, the next time you get it out replace it with a hex plug.
/ Drain plug 3/8 +/- #12
Slightly larger than 3/8" is 10mm. (0.393" to be exact). 7/16" = 0.438"
I think he is trying to use the 1/2" (square) drive end, not the actual socket end.
I've done this before with square heads plugs, nuts.
Correct. It is a square 3/8 head and I am using the drive end of an extension not a socket.
/ Drain plug 3/8 +/- #14
Yes, I've done same with a socket where you can find the right 3/8 drive 12 point socket that will fit on a 3/8 drive ratchet.
The socket is less likely to round out than the plug.
Trying to recall where I have seen plugs with recessed square heads? Conduit plugs?
/ Drain plug 3/8 +/- #15
They make sockets for plugs- Of course, I found this after chewing one into oblivion so now I have a set.
/ Drain plug 3/8 +/- #16
Looks like you got the last one... :unsure:
/ Drain plug 3/8 +/- #18
I have a lot of tools but it just never occurred to me that I really needed one until I had one really seized up. I went to Lowes and nothing. Seemed odd that I never ran across them before but sure enough, I found a set and bought them. I paid a hefty price to replace that d*&^ vent tube coming out of an Onan generator. It was something I didn't know existed much less to open it and clean out the soot periodically.
/ Drain plug 3/8 +/- #19
/ Drain plug 3/8 +/- #20
2014 DODGE CHARGER (A62130)
2014 DODGE CHARGER...
2014 Jeep Grand Cherokee SUV (A61569)
2014 Jeep Grand...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A62131)
UNUSED JCT 84" HYD...
2006 Volvo VNM T/A Day Cab Truck Tractor (A61568)
2006 Volvo VNM T/A...
Zero Turn Mower (A59231)
Zero Turn Mower...
2007 Maserati Quattroporte (A61569)
2007 Maserati...
