DR Brush mower deck
   / DR Brush mower deck #1
Mike058
Key Peninsula, Wa
Kioti CK3510SE
I haven't gotten a chance to take it out for a spin yet. But in trying to move from one part of the shed to another, I stepped on the deck in order to get over the machine (no room to go around). I weigh 180 and the deck didn't flex a smidge. Solid like a tank.
I have the thicker blade for it and was wondering if a 1/2" breaker bar will be enough to remove the nut.
   / DR Brush mower deck #2
Mike;
A 1/2" breaker bar will be enough to remove the blade. I'm curious to hear from you if your "heavy" blade is that much different from the "regular" blade. I didn't see much difference between the two when I installed mine.
SimS
   / DR Brush mower deck #3
I haven't put the thicker blade on yet, there is still room on the original for many more sharpening. The heavy duty one is thicker.
Not sure what a breaker bar is?
But it is quite an ordeal to loosen the nut to get the blade off, I sharpened it after one year, pretty beefy.
Breaker bars are great. Long steel handle with a fitting on the end for a socket. Makes any guy Superman. I use a 3/4" bar to loosen and tighten the trailer balls onto the ball mount. The 1/2" one gets lug nuts on and off the truck or van.
(1) UNUSED 5200# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 5200#...
Makinex Power Lifter (A52377)
Makinex Power...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
HYDRAULIC PTOS (A53843)
HYDRAULIC PTOS...
