DR Brush Cutter
/ DR Brush Cutter #1
pbbraun
Evergreen, Colorado
Kubota BX 1500
I have a DR brush cutter that I am trying to restore. The wires have cut and I need help figuring out the connections. IMG_0348.jpgIMG_0353.jpgIMG_0352.jpgIMG_0350.jpgIMG_0315.jpgIMG_0351.jpgIMG_0347.jpgIMG_0349.jpg
/ DR Brush Cutter #3
/ DR Brush Cutter
I still have a wire with no home. It is an orange wire with a connector on the end. It is shown on the pictures in my post.
How do you hot wire the brush cutter. I don稚 have a key. I checked YouTube and the only have examples of how to do it with a lawn tractor and it is different.
Thank you for your help.
Bill
/ DR Brush Cutter #5
Keys are standard - one of two common lawn tractor keys. If there is no little solenoid at the base of the carburetor, all you need to do is unhook the wire to the coil and jump across the solenoid (or to the starter lug with the + and momentarily touch the ground to a safe spot on the chassis to crank the engine). The coil is grounded to kill the engine. Never any power to the coil. That will tell you if it runs. Then either pick up a harness or wire it as it should be.
Fencing Wire (A62613)
John Deere 316 Riding Mower (A66408)
John Deere 316...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2 Rolls of Screen (A62613)
2 Rolls of Screen...
Sitrex 2GL-T Hay Tetter (A65640)
Sitrex 2GL-T Hay...
Aluminum Alligator (A65583)
Aluminum Alligator...
