DR Brush Cutter
/ DR Brush Cutter #1
pbbraun
Evergreen, Colorado
Kubota BX 1500
I have a DR brush cutter that I am trying to restore. The wires have cut and I need help figuring out the connections. IMG_0348.jpgIMG_0353.jpgIMG_0352.jpgIMG_0350.jpgIMG_0315.jpgIMG_0351.jpgIMG_0347.jpgIMG_0349.jpg
/ DR Brush Cutter #3
/ DR Brush Cutter
I still have a wire with no home. It is an orange wire with a connector on the end. It is shown on the pictures in my post.
How do you hot wire the brush cutter. I don稚 have a key. I checked YouTube and the only have examples of how to do it with a lawn tractor and it is different.
Thank you for your help.
Bill
/ DR Brush Cutter #5
Keys are standard - one of two common lawn tractor keys. If there is no little solenoid at the base of the carburetor, all you need to do is unhook the wire to the coil and jump across the solenoid (or to the starter lug with the + and momentarily touch the ground to a safe spot on the chassis to crank the engine). The coil is grounded to kill the engine. Never any power to the coil. That will tell you if it runs. Then either pick up a harness or wire it as it should be.
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
2022 EZ-GO ELITE...
4" Makita Disc Grinder (A62613)
4" Makita Disc...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
