Dozer Blade for in the Woods
   / Dozer Blade for in the Woods #31
Great story! I just did my JD 450 too. I put 2 sprockets, 10 rollers, rebuilt both idler tensioners,and repainted u/c. It was definitely a lot of work. I had to use the torch to heat up several bolts on the rock guards.
   / Dozer Blade for in the Woods #32
Wow, that's a job (repair) I wouldn't tackle!! I am jealous of that dozer though!
   / Dozer Blade for in the Woods #34
I don't know how I missed this thread. Good job Gordon!! You gave me a few pointers on what to look for on my dozer.... thanks, it helped a lot. I went and looked at an excavator and the track was shot. The salesman insisted there was 70% left, he got mad when I called him out. I feel bad for the poor guy that's going to walk into that mess. There's nothing worse than buying something and having to spend another $4k to rebuild an UC.
   / Dozer Blade for in the Woods #35
I don't know how I missed this thread. Good job Gordan!! You gave me a few pointers on what to look for on my dozer.... thanks, it helped a lot. I went and looked at an excavator and the track was shot. The salesman insisted there was 70% left, he got mad when I called him out. I feel bad for the poor guy that's going to walk into that mess. There's nothing worse than buying something and having to spend another $4k to rebuild an UC.
And that would be my problem if buying a track unit. I don't know how to determine it's condition.
   / Dozer Blade for in the Woods #36
I don't wanna hijack Gordons thread but Look at his pictures. See how the chain bushings are wore through to the pins? Don't believe them when they tell you "just pull the pads off and rotate the bushings". It's not happening. For laughs, I put a 2' pipe wrench and a 4' pipe and couldn't rotate them. You'll see the wear groove in the bottom rollers, upper roller and idlers. Sharp tips on the sprocket. Look at the chain tightener cyl, if it's at the end of its stroke, bad UC. Look how far the idler is pushed forward, if it's close to the end.... Bad UC. My final drive is different than Gordons. The splines of my sprocket would move fwrd/rev a 1/2", almost everything was shot and had to be replaced. Look at the chain tensioner spring assembly for excessive rust, they're very expensive to replace and a pain to rebuild. Look at the tips of the shoes/pads, if they're worn down, there's a good chance the UC is bad too.
The best thing to do is bring someone with you that knows what they are looking at. I found a dozer that I thought I might want and then brought a equipment guy that knows dozers to look at it. But realize it is still a gamble and don't put a burden on him just get his opinion. There is so much you can't see. In my case I new the u/c was shot but there are a ton of other things that a well experienced guy can see or feel.
gg
   / Dozer Blade for in the Woods #38
If I ever get in the buying mode, I'll be talking to you Gordon!!!! :)
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A55973)
2015 Peterbilt 348...
towable floodlights (A56857)
towable...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
VERMEER PD10 PILE DRIVER (A52709)
VERMEER PD10 PILE...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
