Posthole Digger Down pressure
/ Down pressure #1
LlanoLonghorn
Llano, Texas
Mahindra 4025
Can a FIL be used to apply down pressure on a 3P post hole digger? I was thinking if you put the bucket down on the ground with a little pressure that would transfer back to the PHD as down pressure. Just asking.
/ Down pressure #2
I don't think so because your 3 point will float up.
/ Down pressure #3
I think he meant another tractor's FEL would be used to push down the PHD on the first tractor.
I've never tried it but it sounds dangerous.
Edit: OOPS - I misunderstood. dfire is exactly correct.
/ Down pressure #4
FIL = texting lingo for father-in-law. Some of 'em would work great for down pressure on the auger ! All ya need is a little perch for them to sit on. :thumbsup:
Not trying to give you a bad time, but I just couldn't resist that image. :) Just for fun, of course... that wouldn't be safe. I'm pretty sure the other guys are correct about using the loader like that... the 3 point only holds position in the downward direction and will lift up.
Welcome to TBN, by the way.
/ Down pressure #5
Actually I've done that.
Last summer it was hot and dry and the ground was very hard. I have a post hole auger on an L3830 and it was making powder but not moving down much. My wife pulled up on her B2620 and slowly lowered the loader bucket until the bottom of the bucket was touching the top of the PHD frame. A little down pressure was applied (not much) and the auger started moving down. She immediately raised the bucket and backed away. The safety guys will jump on this but the way it was done did not feel unsafe at all.
KW
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
UNUSED CFG INDUSTRIAL MX20R MINI EXCAVATOR (A62130)
UNUSED CFG...
2025 LandHonor RB-14-78W 78in Tooth Rock Bucket Skid Steer Attachment (A60353)
2025 LandHonor...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2025 4-Way Hydraulic Clamshell Bucket Mini Skid Steer Attachment (A60353)
2025 4-Way...
2010 Ford Crown Victoria Sedan (A61569)
2010 Ford Crown...
