Double Tow
/ Double Tow #1
Seon
Lake Camanche, CA
JD 4210
In an RV forum, it's quite common to pull a 5th wheel trailer and another trailer behind that, thus double towing.
I just bought a 24' gooseneck trailer to transport my JD 4210 w/FEL and backhoe attachment. In addition, I want to haul the box scaper and another FEL w/tooth bar. I also want to tow a 6'x10' bumper pull dump trailer behind the G/N.
Anyone ever do this? If so, can you share your experience?
/ Double Tow #2
You must have fairly big truck.. I have seen an RV'r or two double towing. I wonder what the weight differences between the RV situation, and what your asking, would be?
tim
(seon, pardon the change of discussion: still have the t/w bh? and are you still happy with it.? I got a 760 seems ok so far.)
/ Double Tow #3
I'm not sure it is legal to tow double trailers without DOT approved connections. Semi's have to have approved couplers.
Also you will need a class A or B licence with Doubles/ Triples endorsement if it's comercial. I have the class A with D/T endorsement but I can't remember questions on the test about types of couplers.
/ Double Tow
irwin said:
....(seon, pardon the change of discussion: still have the t/w bh? and are you still happy with it.? I got a 760 seems ok so far.)
Tim, Yes I still have the T/W bh. I just helped my nephew by digging a trench for a retaining wall at his new home. I really like it. I still need to build a subframe for it. Hopefully by this summer.
BTW I've contacted a couple of company that sells T/W to buy a 12" bucket. Seems like pulling hen's teeth finding one. I think I'll try fabricating one myself.
Regarding double tow...the gooseneck trailer I bought has a 2" receiver on it, so apparently it's design to tow another trailer(?) .
I'll ask the Hwy Patrol to get their ruling...being they'd be the one who'll be pulling me over and giving me a ticket LOL.
Why double tow you ask?...Well I'll need to return to my nephew's house (three hour drive) to backfill behind the retaining wall. The JD will be on the G/N trailer along with a couple of implements. The excess dirt will have to be hauled away from his house in the dump trailer. I'll be towing both trailer (if it's legal) with a Silverado 1 ton dually.
/ Double Tow #5
Yes I'd ask the state police and if they said yes (get a name&badge# of who you talked to) I'd do it, no problem...;)
(Got my subframe almost ready, will post pics when done...tim)
/ Double Tow #6
i see guys pulling bass boats with the wave runner behind it all the time.
or an dulley pulling a 5th wheel RV pulling boat etc.
I see utility trailer guys (the guys that build them) pulling doubles all the time.
/ Double Tow
schmism said:
...I see utility trailer guys (the guys that build them) pulling doubles all the time.
This G/N trailer I bought has a 2" receiver so it's made to tow something behind it. LOL
/ Double Tow #8
Here in Indiana your you can double tow as long as the rigs total length is under 65', 26,000#, and all trailers over 3,000# must have brakes with a break away system. I have done it and it is no problem. Just make sure your truck can handle it and you plan your stops. You don't want to have to back up at a gas station or something like that.
I looked up Cali's law and its the same as Indiana. Over 26,000# you need a CDL.
Chris
/ Double Tow #9
I was also wondering about the same thing. I also have a 24' GN w/2" receiver hitch on the back and would like to take my dump trailer along with sometimes.
/ Double Tow
I just spoke to a CHP officer who said that a CDL is required to tow double with a 5th wheel/GN apparatus.
/ Double Tow #11
Semi trucks in OR pull tripple trailers... take about scarey... just watching them go down a mountain pass on I-5 makes you want to pull off the road.
mark
/ Double Tow #12
They used to let truckers on the NY Thruway pull a pair of 48' trailers. The first time I saw that my jaw was dragging on the pavement.
About 2 years ago I saw an F350 dually pulling a big gooseneck horse trailer AND a 30' bumper-pull house trailer. This was in heavy traffic on rt 206 in Hillsborough. He was having trouble moving the load and was getting NO respect from Jersey drivers.
No way I would pull doubles in NJ or the northeast.
/ Double Tow #13
My stepfather looked into pulling doubles and from what he was told it goes by your home state. If they allow doubles/triples you can do so from state to state. I'm sure there will be some catches but from the replies its sounds legal and feasable. But just be careful of your weight. From what I've gathered your pulling your tractor on the GN and the dump empty. Then using just the dump when you get to the job. That sounds perfect. I don't have a dump for just that reason. I'm already at my max weight with just the GN. Good luck, Robbie
/ Double Tow #14
Robbie Hegwood said:
My stepfather looked into pulling doubles and from what he was told it goes by your home state. If they allow doubles/triples you can do so from state to state. I'm sure there will be some catches but from the replies its sounds legal and feasable. Good luck, Robbie
Your stepfather was given bad info. PA for one does not allow recreational or personal double towing.
As mentioned, double towing does come up in the RV threads. More than one has mentioned having to drop a trailer then come back for it later with just the tow rig.
/ Double Tow #15
They still do. There are service areas ajacent to many of the toll booths for breaking down the combo's in order to access local roads.
No big deal with the proper training.
/ Double Tow #16
I have a 20+5 Moritz gooseneck. It also has a receiver in the rear of the trlr, it is for raising and lowering the dovetail. The jack locks into the receiver and either raised or lowers the dovetail. Mine is not for towing, yours may not be either. The Old Gunny
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
