Double-ended
/ Double-ended #1
RFB
Platinum Member
None
lift arm pins? Is there such a thing as a (one-pices) long lift arm with pins on each end? I want to construct a ballast box using concrete and wanted a single long rod terminating in pins at each end to span the width of the box.
Thanx
/ Double-ended #2
I used a drawbar. Its a single peice of iron with a row of holes. They have pins on the end cast as a solid piece.
Speeco makes various hitch accessories that are available at many ag supply and tractor dealers:
Speeco Drawbars
- Rick
/ Double-ended
Thank you very much gentlemen!
RFB
/ Double-ended #5
I used a piece of 7/8" steel rod.
/ Double-ended #6
I used a cheap surplus drawbar bolted to the bottom of this counterweight.. etc.
Or as others said... use a 7/8 rod.. or piece of rebar even.
Soundguy
Kivel Quick Hitch Mini Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2022 EZ-GO ELITE...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A64553)
2025 Hydraulic...
2018 KUBOTA SVL95-2S SKID STEER (A65053)
2018 KUBOTA...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2024 Ford Explorer AWD SUV (A64557)
2024 Ford Explorer...
