Double-ended
/ Double-ended #1
RFB
Platinum Member
None
lift arm pins? Is there such a thing as a (one-pices) long lift arm with pins on each end? I want to construct a ballast box using concrete and wanted a single long rod terminating in pins at each end to span the width of the box.
Thanx
/ Double-ended #2
I used a drawbar. Its a single peice of iron with a row of holes. They have pins on the end cast as a solid piece.
Speeco makes various hitch accessories that are available at many ag supply and tractor dealers:
Speeco Drawbars
- Rick
/ Double-ended
Thank you very much gentlemen!
RFB
/ Double-ended #5
I used a piece of 7/8" steel rod.
/ Double-ended #6
I used a cheap surplus drawbar bolted to the bottom of this counterweight.. etc.
Or as others said... use a 7/8 rod.. or piece of rebar even.
Soundguy
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
JCB 3TS-8T TELESKID SKID STEER (A65053)
JCB 3TS-8T...
2015 Ford F-250 Ext. Cab Pickup Truck (A64556)
2015 Ford F-250...
2014 Chevrolet Express Shuttle Bus (A64556)
2014 Chevrolet...
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
