Double ended forks mod
/ Double ended forks mod #1
Aquamoose
Platinum Member
Deer Park, WA
Branson 3520h
I bought a 48” quick attach pallet forks from Titan and wanted it to be useable on the back end so I added two steel plates with holes, bought 3ph pins, and voila! It’s so simple that it should be a product offering. Anyone else do this too?
/ Double ended forks mod #2
Nice! Great job!
I've been meaning to do the same with my set of pallet forks as well, as I had plans to lift something very heavy just a foot or so off the ground and the 3 pt is way more suitable for heavy lifting than the loader. That heavy lifting never happened so I post poned that mod.
It will also makes it very easy to pick something heavy to be used as counter weight.
Exactly. During splitting sessions, I can keep my grapple on the front to move logs to cut/split while moving filled totes.
/ Double ended forks mod #4
Nice job! The hydraulic top link will be real handy for adjusting the forks when backing under the totes.
I realized that it’s tricky to get it dialed in to the right height so I built a 3PH limiter that I fabricated in two hours. I forgot to take pics of it. I could adjust the stops via set screw and all I have to do is just drop it against the stops and it’ll go to the same position, perfect height for the forks to pick up or drop off pallets.
/ Double ended forks mod #6
Not pallet forks, but the Speeco UltraFork is made for front or rear:
I added a longer spear for 5x6 round bales:
/ Double ended forks mod #8
A tree puller is another candidate for conversion to 3 point.
This was made for LouieJunior by: Buckthorn Puller
For SSQA and 3 point:
/ Double ended forks mod #9
Good idea. Being a bricklayer I cant lift some heavy pallets with my loader but could with 3 point. Might have to do this during winter layoff.
Jeff
I realized that I needed an adjustable stop for the 3ph to stop at a certain point off the ground so I whipped this up. One “before” shot ad two “after”’s. Now I can dial the stop settings so my forks hovers just above the ground each time.
/ Double ended forks mod #11
That's a very good adjustable stop you implemented and a good addition to your tractor ! I have a factory version on mine and use it quite often.
gg
/ Double ended forks mod #12
We did that with a set of forks a couple years ago so we could haul IBC totes to the woods to collect maple sap.
David
/ Double ended forks mod #13
Been wanting to do your mod for my forks for sometime. Nice to see it done. Bobcat forks require little more custom fabrication. Great job on your position stop.
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
8ft. Metal Drag (A65640)
8ft. Metal Drag...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
