Double Chute Snowblower???
/ Double Chute Snowblower??? #1
Klorinth
Winnipeg, Manitoba, Canada
Montana T2334 HST
Is anyone able to identify the snowblower in the attached pics?
I found it advertised on Kijiji near me.
I am interested in learning more about it.
It is 5' in width. The chutes are electric rotation using a chain. That is all I can tell so far.
Any ideas?
/ Double Chute Snowblower??? #3
The blower operates 90 degrees different than most. I remember seeing a blower with that orientation a looong time ago. Cant recall how well it works. :confused:
You think so?
The chutes are connected in a pretty seamless way, and it you look closely the top sheet metal is a single piece and not connected. The 3ph mount could be homemade...
I can't be sure though. That is why I was interested in hearing if there is anyone here that has heard of a double chute snowblower before.
How about the style of dual stage? Does that look familiar?
Can you explain what you mean by 90 degrees different? I don't think I'm understanding you.
/ Double Chute Snowblower??? #6
Any ideas?
The twin spout caster will plug less for sure and the tractor can be run more slowly with near zero plugging.
I do no not know the manufacturer but the type has been discussed before-possibly Hesston?, as the paddle wheel impeller was a very simple way to get rid of the snow but it was a bit slower as the paddle wheel impeller was less likely to jam from plugging
The two spout snow caster is a common sight in europe in road snow clearing and also at ski resorts.
Interesting... Now I get the "90 degrees" difference. I had noticed that.
I hadn't thought about the clogging being reduced but I could see that working.
The price is right, so I am tempted to buy it. I just don't know how solid and reliable it will be over time. I am just getting into welding so I will be able to do some work on it and make it stronger if needed, but I would rather not buy something that requires lots of work. I don't have a good shop to work in, I'd have to go to my sisters place for that.
I'll look up the Hesston suggestion.
Thanks.
/ Double Chute Snowblower??? #9
Re: Double Chute Snowblower??? = BobCat
That snowblower attachment was made by BOB-CAT, then also known as Wisconsin Marine. (Not to be confused with the skid-steer loader manufacturer 'Bobcat', which is an entirely different company.)
You can barely see the Bob*caT logo in the 2nd pic, on the chain cover between the two chutes. It's a decal like this:
A buddy and I have a couple of the small walk-behind BOB-CAT snowthrowers. They aren't uncommon in my area, but I've never seen this tractor implement version. It does resemble two BobCat 30" commercial walk-behinds stuck together. I'd gamble the augers and impellers are the same parts between them.
Company ownership passed through several hands to become the present day BOB-CAT turf equipment manufacturer, a division of Schiller. Little is on their website, but you might try writing them for more info:
Our Legacy | BOB-CAT Commercial Mowers
Schiller Grounds Care, Inc.
One Bob-Cat Lane
P.O. Box 469
Johnson Creek, WI 53038-0469
/ Double Chute Snowblower??? #10
Never seen one like it, either,,
but it does look like it could handle snow without problems, do you have a pic of the back.
/ Double Chute Snowblower??? #11
My old walk-behinds are little beasts, but none of that fancy new-fangled remote deflector/chute control or heated grips fluff. I'd imagine a 3ph attachment version would throw just as well.
Pics in this post are probably the best I've seen. There was an eBay ad for one last summer. 2 grainy images, & local pickup only in Pennsylvania IIRC; Think it got a single bid for $25.
Wonder if the OP ever did decide to take it home?
2016 Freightliner 108SD T/A Rolloff Truck (A64194)
2016 Freightliner...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2023 TOPCAT 4IN1BCT (A67148)
2023 TOPCAT...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2019 CATERPILLAR 279D SKID STEER (A65053)
2019 CATERPILLAR...
2022 Chevrolet Tahoe SUV (A64557)
2022 Chevrolet...
