Do's and Don'ts and recommendation for buying a PTO driven electricity generator?
   / Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #1
Sid Post
Platinum Member
TX and OK
Massey 5711D, Kubota L4600, Kubota B2601
With Texas electricity costing (price capped) $9,000/KWHr :eek: and Natural gas going from $10 to $1,000 per 1,000 cubic feet :eek: IF you were still connected to the electric or natural gas network, the cost of a "Generac" whole house system doesn't seem so significant right now. That is not to mention water damage from the frozen pipes when the rolling 'blackout' hits your house.
I was looking for something to drive my 230V welder versus buying a Diesel or Gasoline powered welder but, now I'm thinking I need to consider something bigger with a house conversion switch (I don't want to back charge and kill linemen working on the power grid ;)).
So at this point, I see the following options:
  1. A diesel powered generator like a stand alone Kohler, Cummins, or Onan unit
  2. Solar would work for the house until is snows or ices over
  3. A natural gas powered "Generac" would work until natural gas is cut off goes to 100 times normal rates
  4. Or, best a tractor PTO powered generator that will drive my welder and a reasonable load of space heaters and general electrics
Without installation costs, Solar is in the $6K~$8K range and an appropriately sized "Lowes" Generac household power natural gas powered unit is about $6K. An Onan, Kohler, Cummins stand along diesel unit is ~$8K.
That makes the thoughts about a larger PTO-powered electric generator seem a lot more practical and it will not be a uni-tasked since I can power stuff remotely like my welder to fix my pipe fence and other things like spinning a concrete mixer away from the house.
As a starting point, I think the diesel tractor-powered generator is my best option but, I'm probably overlooking some factors in my choice. Also, where should I start looking for a PTO-driven electric generator?
TIA,
Sid
   / Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #2
Well if you are running a PTO generator you tractor is dedicated to that task and you lose its usage for other thing while you require electricity..... I have always been in the mind frame to have stand alone generator dedicated for just generator use and have tractor available to pull wife's car or my truck out of mud bog or remove snow or mud or what ever you may need to use a tractor for....
THE do make dual fuel generators that run on gasoline or propane.... IF fuel is issue... But a dual fuel running on propane only produces about 80% of the wattage than when running on gasoline....
Personally If I were going whole house (including welder) I would go a standalone unit (Generac or similar) and whole house auto transfer switch , many in my area have those and run them on propane....
Dale
   / Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #5
I use a 10k PTO powered generator;if I need the tractor for something.................takes five minutes to unhook it or hook it back up.
We got through the ice storm of 1997(out for four days) with a 2500watt gas job for four houses.After that everyone in the area has some form of back up.
   / Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #6
There are a bunch of current threads on this (no pun intended). There really is no one single right answer that fits all people, just like tractors and cars and trucks.
   / Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #7
I use my 15kw pto generator to power my welder, many times just to exercise my generator., it works perfectly..
My pto generator is one of my BEST buys!
SR
   / Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #8
I'll never understand the argument that the generator ties up the tractor. If you need the tractor unhook it and use it. You will only be out of power for that long. If you consider the price of a PTO machine as well as the fact that you can easily stockpile diesel fuel it's a no brainer. I love my 25 kW. I wouldn't have a standby after using the one I have. I think I paid $1100 for it. And built a trailer for it that my welder will sit on if needed.
   / Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #9
My 25kw pro generator is trailer mounted.
Many times I will just back up to it and connect the pto shaft and power line and not even bother connecting the draw pin.
I also have a backup tractor that I can use if i need the other one for snow plowing or something else.
This generator is 25 years old now it's a 4 pole so it spins at 1800 rpm with a 540 rpm input,
my main tractor for it has an economy setting for the pto so I can get 540 at about 1750 engine rpm.
I went with a trailer as to me that is easier to hook to if I want to move it or take it some were else.
Several years ago I went from my place to my brothers about 3 times a day with it,
we had a several day outage and 5 places needing electricity so his big one was tied up for the farm and we went to
the other locations in rotation to keep every thing up and running. I'd hook up to the pickup run over with put one of his tractors on it
use it for 1 or 2 places then back to my place with the truck. We had all the houses setup for a 50 amp cord setup so it was quite and easy
to power up and down. My generator has a full power 100 amp connector as well as the 50 amp cord receptacle and the 20 amp duplex.
If the tractors are not hooked up to something it's just a matter of a few minutes to startup, backup connect and start powering the house.
And another nice thing with a pto unit you can get a larger unit then your tractor can handle for full capacity and if you get a larger tractor
the generator is ready. Such as my 25Kw needs about 50hp on the pto if you are using everything that it can produce but if you put a 25 pto hp
tractor on it you could still generate around 12.5 Kw.
   / Do's and Don'ts and recommendation for buying a PTO driven electricity generator? #10
Lou, I have mine mounted on a trailer with a 2" ball and have it wired to a 100 amp panel mounted on the trailer with 240 volt and 120 volt outlets and lighting on the trailer. You know you never need a generator in the daylight. There's enough room on the trailer to sit my welder, air compressor and any other items I may need to do remote work on the farm.
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
CATERPILLAR...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
