Sid Post
Platinum Member
- Joined
- May 28, 2010
- Messages
- 753
- Location
- TX and OK
- Tractor
- Massey 5711D, Kubota L4600, Kubota B2601
With Texas electricity costing (price capped) $9,000/KWHr
and Natural gas going from $10 to $1,000 per 1,000 cubic feet
IF you were still connected to the electric or natural gas network, the cost of a "Generac" whole house system doesn't seem so significant right now. That is not to mention water damage from the frozen pipes when the rolling 'blackout' hits your house.
I was looking for something to drive my 230V welder versus buying a Diesel or Gasoline powered welder but, now I'm thinking I need to consider something bigger with a house conversion switch (I don't want to back charge and kill linemen working on the power grid
So at this point, I see the following options:
Without installation costs, Solar is in the $6K~$8K range and an appropriately sized "Lowes" Generac household power natural gas powered unit is about $6K. An Onan, Kohler, Cummins stand along diesel unit is ~$8K.
That makes the thoughts about a larger PTO-powered electric generator seem a lot more practical and it will not be a uni-tasked since I can power stuff remotely like my welder to fix my pipe fence and other things like spinning a concrete mixer away from the house.
As a starting point, I think the diesel tractor-powered generator is my best option but, I'm probably overlooking some factors in my choice. Also, where should I start looking for a PTO-driven electric generator?
TIA,
Sid
- A diesel powered generator like a stand alone Kohler, Cummins, or Onan unit
- Solar would work for the house until is snows or ices over
- A natural gas powered "Generac" would work until natural gas is cut off goes to 100 times normal rates
- Or, best a tractor PTO powered generator that will drive my welder and a reasonable load of space heaters and general electrics
TIA,
Sid
