Dongfeng DF-254 Help
/ Dongfeng DF-254 Help #1
gbonsell
Tyrone PA
DF254
Hi all, my name is George, I am located in central PA, a couple months before my Father passed away he bought a used 2004 DF-254, 25hp engine Y385 it has a little over 700 hrs on the motor. looking for info on this tractor like, parts list, where I can get parts. it seems like it is a good tractor all the more we used it but it needs some tlc I have changed the oil and checked all fluids. and changed the fuel filter that is bolted to the motor is there another one also? it has the Koyker 160 loader and I have the book for that but not the tractor. it also has a hoe attachment but I do not know what kind. Any kind of info will help.
Thanks George
/ Dongfeng DF-254 Help #2
Devonn tractors sells Dong Feng tractors. The information page (see link) gives some links for literature that will probably be handy for you.
HTH
Information
/ Dongfeng DF-254 Help #4
Where the fuel line comes down from the tank to the lift pump there is a banjo fitting. Switch off the fuel at the tank, then undo the bolt on this banjo fitting. I think it is 16mm AF weird size.The bolt is hollow, and inside there is a tiny mesh filter. If the tractor has done much grass work the filter will be clogged. Blow it clean with air pipe, rinse in diesel fuel, blow it through again, and put it back together. DO NOT LET GO OF THE FILTER WHILE YOU BLOW IT THROUGH! The filter is about 1" long and 1/4 " diameter and very difficult to find in a messy workshop. Guess how I know this. :)
Thanks Ross71, I will give this a try.
New/Unused Deluxe Massage Chair (A65583)
New/Unused Deluxe...
ASV Engine & Parts (A66285)
ASV Engine & Parts...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2018 Kubota SSV 75 Skidsteer (A66285)
2018 Kubota SSV 75...
2019 Chevrolet Tahoe (A64194)
2019 Chevrolet...
