DOM tubing question
/ DOM tubing question #21
Last time I tried acting like a mechanic under a shade tree the silly thing dropped a branch on the hood. Then I had to act like a shade tree body man.
/ DOM tubing question #22
seems to me the bushing and pins dont move relitive to each other, only the cylinder bushing rotates
so you dont need clearence for greese, measure the cylinder bushing diameter and work from that
if im right i would just put a bolt through the weldiments and a spacer for the cylinder and weld them in place, weld a lil at a time to control heat and alternate sides when welding
a class 5 or 8 bolt should be a few thausanths under and can be polished a lil more under where the cylinder bushing is
even if you have to drive the bolts into the welded bushings it shouldnt matter, only the cylinder bushing clearance matters
when you use the spacer make sure its atleast .010" longer than the cylinder bushing for grease to seep out the ends for lube
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
Massey Ferguson Model 66 Hay Rake (A65640)
Massey Ferguson...
Aluminum Alligator (A65583)
Aluminum Alligator...
2024 MODASA  MH25-I GENERATOR (A65643)
2024 MODASA...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
International 400 4R Planter (A66408)
International 400...
