Dolly wheel question
/ Dolly wheel question #1
anthonyk
houston texas
Century 3647
I know this is probably a dumb question but....
Any suggestions on how to reinflate a dolly (hand cart) wheel once it's totally flat?
I've got one of those simple grey Milwaukee dollys, the kind you stack a box on, tilt back and roll. The wheels might be 8 inches, and they've got the standard tire valve stems to inflate.
The other day I went to use it, and both were really low.
No problem, I've got my trusty air pump. BUT when you try to inflate the tires, the air just runs out around the wheel hub.
I've tried holding the tires, squeezing them, cursing them, but no go. I have it admit, I finally started laughing.
Now, I'm open to advice. Any suggestions? /forums/images/graemlins/confused.gif
Anthony
/ Dolly wheel question #2
You know not to long ago we had the same problem here. Problem was the tubes were to old to hold air anymore and replacement tubes were $6ea+shipping. We have a harbor freight store close by and looked in their to see what they had. Well as luck would have it they not only had the tubes but for another .50ea you could buy the whole assembly (rim, tire with tube) so we walked out the store with new wheels and tires for under $15. /forums/images/graemlins/smirk.gif
/ Dolly wheel question #3
I had the same problem a couple months ago. My tires were tubless and i was using a air compressor. i tried squeezing the tier and ever other trick i could. I was kind of cool that day, my dad said he would take care of it. a week later he said he fixed the flat /forums/images/graemlins/confused.gif, he said he just put air too it and it pumped up , It was warm the day he did it so the temp. must have made the diff.
/ Dolly wheel question #4
Assuming they are tubeless tires....
Take a piece of rope long enough to go around the tires tread with some extra. Tie a knot so you have a loop. Sick a piece of pipe or wood through the loop and twist it as you would a touniquet. This will compress the tread and force the tire's bead against the wheel. Now add the air.
A small rachet type tie down strap will work too.
/ Dolly wheel question #5
first thing to do is remove the core from the valve stem so the full amount of air can "rush" into the tire. Then once it is inflated, put your finger over the valve stem. Grab the valve core and using the core removal tube, reinstall the core. Make sure to be wearing face protection, so if the core flies out, it won't do any damage to you. This is how they do it at the tire stores, but I have never seen any of them use face protection. Guess thats the difference between an amateur and a professional.
/ Dolly wheel question #6
</font><font color="blue" class="small">( Assuming they are tubeless tires....
A small rachet type tie down strap will work too. )</font>
That's exactly how I do it. Works great.
/ Dolly wheel question #7
Anthony if you follow the above advice that others have given and you are lucky enough to get air in your tires I might recommend pumping in a bit of Slime to keep this from happening ever again.
I put it in the air compressor tires, gas welding cart tires, and 2 hand dolly's. I think mine were just going flat from inactivity but they haven't given me any grief since I gave them all an injection.
/ Dolly wheel question #8
<font color="blue">I might recommend pumping in a bit of Slime to keep this from happening ever again. </font>
Preventative maintenance, that's not a bad idea. But what is a bit? 1 ounce, 1 pint, for what tire size etc. Could you elaborate on this little bit? /forums/images/graemlins/grin.gif Thanks.
/ Dolly wheel question #9
Gerard if you pick up any bottle of Slime you will see an application chart on the backside. It doesn't take a lot of Slime for the smaller tires but you should use the amount that they recommend for your tire size. Just make sure that you do get the right formula as they make the stuff for tube and tubeless tires. I have seen it at TSC as well as Harbor Freight, two of my favorite places to visit. /forums/images/graemlins/grin.gif
/ Dolly wheel question #10
The rope idea works great, but what I do is use a couple of long, stainless steel worm drive hose clamps, screw them together to make a big ring, then tighten them down equally, wont squeeze on side so tight it allows air out of the other side. Works for me.
/ Dolly wheel question #11
I have one like that but the axle has been buggered to the point its a job to replace it so I use a clip on air chuck on my compressor then ad a squirt of either to the bead and inards of the tire and light a stream to it. It pops it up to reseat the bead and works good. Somtimes I have to use a combination of a strap and the either to. The starting fluid method was learned from fixing flats on dumptruck tires to make them reseat. Its very dangerous if too much is used. If you dont have air on it immediatly you will getto watch the fire burn out and cause a vacuum and pull the tire off the bead again.
Ha! /forums/images/graemlins/cool.gif I did it!
I used the "twist the rope" idea and it worked.
Man, I love this site! Thanks for the tips all.
Anthony
/ Dolly wheel question #13
I've done the rope-thing, too and it worked. But I've found that using one of those ratchet-type tie down straps is easier and can generate more SQUEEZE. You also have both hands free.
Doug
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
Sellick S80 (A60462)
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
SET OF (20) ACE CATTLE PANELS W/CONNECTING JOINTS (A63569)
SET OF (20) ACE...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
