Does this look like 5 yards?
/ Does this look like 5 yards? #21
If you have an asphalt plant nearby, they can be a good source of materials. I buy reject asphalt at $10/ton. That's cheaper than gravel here. Spread it with your loader and smash any clumps. It lays down pretty good. The dirt kinda coats the gravel as you spread it out.
I have some of the slickest clay I've ever seen in a side yard, and grass would hardly grow there due to traffic, mostly my truck and trailers. When I spread the reject asphalt out, it was just to increase traction, but the grass started growing over it...
Sounds crazy, but it works.
Mark
/ Does this look like 5 yards? #23
To determine volume needed, take the length in feet x width in feet x (depth in inches / 12), then divide by 27 to get cubic yards.
Example: 12' x 40' x (4" / 12) = 159.984 cu. ft. / 27 = 5.925 cu. yds.
In order to get the decimal equivalent of any whole inch measurement, take the number and divide by 12.
Example: 1" / 12 = 0.0833'
2" / 12 = 0.1667'
3" / 12 = 0.2500'
4" / 12 = 0.3333'
5" / 12 = 0.4167'
6" / 12 = 0.5000'
7" / 12 = 0.5833'
8" / 12 = 0.6667'
9" / 12 = 0.7500'
10" / 12 = 0.8333'
11" / 12 = 0.9167'
Fractions of an inch can be calculated bu taking 0.0833' / fractional unit, then adding back to the decimal equivalent shown above.
Example: 1 1/2" = 0.0833 / 2 = 0.04165' + 0.0833' = 0.12495'
4 1/4" = 0.0833 / 4 = 0.020825' + 0.3333' = 0.354125'
And as for using asphalt and grass growing in it, asphalt makes a great fertilizer. Think about it. All of that old plant matter has been composting for several million years and is now a by-product of oil and is used in asphalt paving. The limestone used in some paving is also a very slow release fertilizer.
I hope that this clears up any calculations needed for volume, and the uses of asphalt for fertilizer.
Regards, Colin
/ Does this look like 5 yards? #24
Change lightbulb?
TBN folks don't change lightbulbs!
If it's burned out, it must mean there's a problem with the fixture.
while you're changing out the fixture, you might as well put in a new switch.
And if you're going to all that trouble, what you really need is a house/barn/garage addition - which means more seat time!
While all this is being planned, the spouse generally gets disgusted and replaces the old incandescent bulb with a new CF one that isn't supposed to burn out in the next 10 years - which just leaves you that much more seat time to play - er, I mean work....
/ Does this look like 5 yards? #25
Erik_in_Hoyt said:
Change lightbulb?
So...Just one, but he's got to do it from the seat of a tractor.
Maybe we should cross link this post to the "trivial uses of a tractor" thread that is going on concurrently. I'm sure someone has tried it with a mini excavator. Maybe Messick Farm Equipment can use this as their next challenge at the town fair.
I'm sure someone in the build-it-yourself forum can design and build a Hydraulic FEL attachment that will change a light bulb.
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2018 JOHN DEERE 310L EP BACKHOE (A65053)
2018 JOHN DEERE...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
