Does the JD 3320 weigh too much to mow over septic tank and lines
   / Does the JD 3320 weigh too much to mow over septic tank and lines #11
Not something I'd want to take a chance on personally, septic systems are too expensive to begin with without damaging one if you can avoid it at all. We use a Craftsman ride-on mower for our entire lawn, although I have driven the L3400 over the area where the line runs from the tank to the leach field when the ground is frozen without worrying about it.
Sean
   / Does the JD 3320 weigh too much to mow over septic tank and lines #12
I've driven my JD 3320 over my septic field since I bought it. We had put patio blocks over the drop box lids to prevent a horse hoof from dropping through if accidentally walked over it (we avoid that), so I avoid driving a wheel over the blocks/drop box lids. Been doing it since 2006 with no issues.
I won't speak to driving over the septic tank. I can understand the bigger risks with that. My advice would be to have a local septic system installer come look at your system and give their recommendations.
   / Does the JD 3320 weigh too much to mow over septic tank and lines #13
Plastic or concrete tanks? I know from personal experience that my 7000 lb truck will collapse a plastic tank cover when I drove over it. I'd be less worried about a concrete tank.
For the drain field, compaction is bad. Will your destroy it with one pass--probably not. Is it good for it to drive over it regularly with a heavy tractor, no.
The official answer is stay off your septic with heavy equipment. The question is what is "heavy" :). In any case stay off it as much as you can.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2018 INTERNATIONAL...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2021 VOLVO VNR DAY CAB (A59575)
2021 VOLVO VNR DAY...
19010 (A55851)
19010 (A55851)
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A59575)
2019 FREIGHTLINER...
