Tires Does SLIME eat away at the inside of the tires????
   / Does SLIME eat away at the inside of the tires???? #11
What???, I have slime in all of our 4-wheeler tires for up to 6 years and have never replaced a tire. now my boys machines we end up replacing/ repairing bent rims quite often. I see the inside of a slimed tire a couple times a year atleast, no tire damage. My machine is the oldest and has had slime in the tires for atleast 6 year no flats and original tires. Some leg pulling going on,
   / Does SLIME eat away at the inside of the tires???? #12
I love slime, I put it in all my tires.
One problem I had was in my backhoe front tire. It had a large plug in it that was leaking and I put slime in the tire. This just made things worse and a slow leak turned into a big leak.
I took the tire to the tire place to get fixed. They said the hole was too big to plug and the slime ruined the inside of the tire for a patch. Once it's on the tire, a patch wouldn't stick.
I had to put a tube in.
   / Does SLIME eat away at the inside of the tires???? #13
Well all this talk about Slime, made me check out
<font color="green">
The Slime Q/A site </font>
I found several interesting facts. Slime is effective for 2 years according to mfg. Can be tightly sealed/stored for 3 yrs.
It may void your tire warranty.
It has been shown to corrode certain rims. (Aluminum - probably on found on the light weight racing tractors... /forums/images/graemlins/smile.gif )
They also don't recommend it in the back tires of tractors just fronts. (if they're loaded)
FWIW,
fwc
   / Does SLIME eat away at the inside of the tires???? #15
Steve;
I went to the web site you referenced. I noticed that Linseal is a UK based company. Do you have any US distributor and/or retail info?
Sim
   / Does SLIME eat away at the inside of the tires???? #16
</font><font color="blue" class="small">( I found several interesting facts. Slime is effective for 2 years according to mfg. Can be tightly sealed/stored for 3 yrs.)</font>
So what happens after two years? Do you add more? Trash the tire..what?
   / Does SLIME eat away at the inside of the tires???? #17
Re: Does SLIME eat away at the inside of the tires
Good question. Sort of like me putting water sealer on my basement walls. Guaranteed 5 years, then what add more of sandblast and re-apply ???
   / Does SLIME eat away at the inside of the tires???? #18
FWC I don't know of any tire sealant that can be used in conjunction with filled tires. Course that is a good argument to use cast wheel weights instead of filled tires and then put the Slime in the tire where it can do some good. I ran it on my last tractor for 5 years and never had a flat. Before that the thorns got me on a regular basis. My tire repair guy wanted me to foam fill the tires. Then a bicycle repair shop gave me the right advice about using "Slime"
   / Does SLIME eat away at the inside of the tires???? #19
I found two brands that are for filled tires and asked the question if anyone had used or knew anything about the product in the Parts/Repair forum and never got any response. Here is a link to the post.... "tire ballast sealers..... good or bad?????
Here is a copy of the post, but you will have to use the above link if you want to get to the websites listed.....
Tire Ballast Sealers...... good or bad...
#332283 - 10/26/03 03:17 PM Edit Reply Quote
I have found two websites for a sealant for ballast loaded tires that claim to eliminate puncture problems. Has anyone here ever used them or do you have any knowledge of them?
Multi Seal Hydro-Seal Tire Sealant
Aqua-Seal: Safe Guard Air Lock
   / Does SLIME eat away at the inside of the tires???? #20
After looking at both websistes, I wonder if they are the same product. Specs are identical, and description is very similar.
Interesting stuff. Didn't know any sealant for water or glycol-filled tires was available. Merits more research.
Thanks.
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
PALLET OF PLASTIC SHEETING & ENTRANCE DOOR (A58374)
PALLET OF PLASTIC...
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
2016 Ford F-350 4x4 Crew Cab Utility Flatbed Truck (A55973)
2016 Ford F-350...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
