Tires Does SLIME eat away at the inside of the tires????
   / Does SLIME eat away at the inside of the tires???? #11
What???, I have slime in all of our 4-wheeler tires for up to 6 years and have never replaced a tire. now my boys machines we end up replacing/ repairing bent rims quite often. I see the inside of a slimed tire a couple times a year atleast, no tire damage. My machine is the oldest and has had slime in the tires for atleast 6 year no flats and original tires. Some leg pulling going on,
   / Does SLIME eat away at the inside of the tires???? #12
I love slime, I put it in all my tires.
One problem I had was in my backhoe front tire. It had a large plug in it that was leaking and I put slime in the tire. This just made things worse and a slow leak turned into a big leak.
I took the tire to the tire place to get fixed. They said the hole was too big to plug and the slime ruined the inside of the tire for a patch. Once it's on the tire, a patch wouldn't stick.
I had to put a tube in.
   / Does SLIME eat away at the inside of the tires???? #13
Well all this talk about Slime, made me check out
<font color="green">
The Slime Q/A site </font>
I found several interesting facts. Slime is effective for 2 years according to mfg. Can be tightly sealed/stored for 3 yrs.
It may void your tire warranty.
It has been shown to corrode certain rims. (Aluminum - probably on found on the light weight racing tractors... /forums/images/graemlins/smile.gif )
They also don't recommend it in the back tires of tractors just fronts. (if they're loaded)
FWIW,
fwc
   / Does SLIME eat away at the inside of the tires???? #15
Steve;
I went to the web site you referenced. I noticed that Linseal is a UK based company. Do you have any US distributor and/or retail info?
Sim
   / Does SLIME eat away at the inside of the tires???? #16
</font><font color="blue" class="small">( I found several interesting facts. Slime is effective for 2 years according to mfg. Can be tightly sealed/stored for 3 yrs.)</font>
So what happens after two years? Do you add more? Trash the tire..what?
   / Does SLIME eat away at the inside of the tires???? #17
Re: Does SLIME eat away at the inside of the tires
Good question. Sort of like me putting water sealer on my basement walls. Guaranteed 5 years, then what add more of sandblast and re-apply ???
   / Does SLIME eat away at the inside of the tires???? #18
FWC I don't know of any tire sealant that can be used in conjunction with filled tires. Course that is a good argument to use cast wheel weights instead of filled tires and then put the Slime in the tire where it can do some good. I ran it on my last tractor for 5 years and never had a flat. Before that the thorns got me on a regular basis. My tire repair guy wanted me to foam fill the tires. Then a bicycle repair shop gave me the right advice about using "Slime"
   / Does SLIME eat away at the inside of the tires???? #19
I found two brands that are for filled tires and asked the question if anyone had used or knew anything about the product in the Parts/Repair forum and never got any response. Here is a link to the post.... "tire ballast sealers..... good or bad?????
Here is a copy of the post, but you will have to use the above link if you want to get to the websites listed.....
Tire Ballast Sealers...... good or bad...
#332283 - 10/26/03 03:17 PM Edit Reply Quote
I have found two websites for a sealant for ballast loaded tires that claim to eliminate puncture problems. Has anyone here ever used them or do you have any knowledge of them?
Multi Seal Hydro-Seal Tire Sealant
Aqua-Seal: Safe Guard Air Lock
   / Does SLIME eat away at the inside of the tires???? #20
After looking at both websistes, I wonder if they are the same product. Specs are identical, and description is very similar.
Interesting stuff. Didn't know any sealant for water or glycol-filled tires was available. Merits more research.
Thanks.
2013 RAM 3500 FLATBED (A58214)
2013 RAM 3500...
2003 Big Tex 10PI...
2011 UTILITY 53FT REEFER TRAILER (A58017)
2011 UTILITY 53FT...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2007 GALYEAN 130BBL VAC TRAILER (A58214)
2007 GALYEAN...
2013 CATERPILLAR 316EL EXCAVATOR (A52709)
2013 CATERPILLAR...
